Results 1 to 5 of 5
    Oct 2003
    Sydney
    ETEC Diagnostic Kit - Want to order. Fault with motor not reving Etec 75Hp
    Hi Guys,
    Asking for a mate who has an etec that will not rev up in neutral or in gear. Throttle opens up but wont rev. He wants to order a diagnostics kit. Is this possible or does it need to be ordered through a dealer?
    Also any ideas what would cause this fault?
    Motor went under water while not running.
    Test the shift interrupt switch. It should be depressed in neutral. Also make sure the throttle is returning completely to idle or it will never let it rev.
    Oct 2003
    Sydney
    Thanks heaps we will try this
    Canada, East!
    Under in salt water or fresh?
    pointer
    Sep 2014
    Florida keys
    Check the tps function also. You can do this by ohm check. I would also check all your harness connections for corrosion due to going underwater. have you done basic checks? Compression/spark? Flywheel key? Does you ecm have all 4 leds active when it's idling?
  6. Likes baja200merk liked this post
  1. Why are ETec G2 H.O. Motors selling for less than the older Etec H.O.'s ?
    By Pachanga_rick in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-05-2016, 01:51 AM
  2. 75hp - 90hp Etec differences
    By Hevi Kevi in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 12-24-2014, 12:42 PM
  3. lost diagnostic software for my etec 150
    By mako23 in forum Technical Discussion
    Last Post: 07-24-2012, 06:08 PM
