Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    The water in the gas was fixed months ago I drained the tank and have checked the water separater everytime I've taken it out since...normally there is a few teaspoons of water in it I drain and then run it...there hasn't been any alarms since then either
  2. #17
    louisiana
    looks like you were lucky
  3. #18
    ct.
    Standard pro. Clean injectors,depending year replace coils,coil drivers,and the fuel pumps mac. And elec. Try to save money and it will come back to haunt you
  4. #19
    Jan 2007
    A year ago, one of my '01 300X burned a hole in #6 just the pic above. I sent it to Chris Carson for a rebuild last winter. The injectors were cleaned. I also replaced both fuel pumps and the coil/driver for #6. 58 minutes into the break-in cycle, it burned holes in #3 and #5. The fuel was fresh and mixed to 94 octane. In both cases, there were no strange sounds or warnings of any kind from SmartCraft.
    I ended up buying a used '05 powerhead which ran flawlessly all season. I'd like to rebuild my '01 to have as a spare, but am worried it will just happen again. I suspect it's in the electronics. I'm curious, could the electronics from the '05 be used on the '01? I see the coil part numbers are different, but would they work?
    2001 Spectre 30 w/twin 300X - sold
    2008 Velocity 390SS w/twin staggered 525efi - sold
    2003 Sonic 31SS w/twin 496HO - sold
    1988 Baja Sunsport 196 w/500HP SBC and 125 shot nitrous - sold
  5. #20
    Apr 2014
    Quote Originally Posted by Mad300x View Post
    Well my 300x decided it wanted to burn a hole in one of the pistons anything worth doing while it gets a rebuild? I was planning on a big bore throttle body and a lightened flywheel anything else that someone should do
    I did the same thing #6 hold... Now I have to do a rebuild too.. Who is doing your?? I need someone GOOD !!
  6. #21
    It's a 300x thing. Chris can do you right and depending on year have the ignitors and coils checked.
  7. #22
    Apr 2014
    Chris Carson
    Key Largo Florida ??
  8. #23
    yessir
  9. #24
    Jan 2007
    Quote Originally Posted by apache 41 View Post
    Yes, Chris Carson. Last time I just sent him the block. This time I'll send him the whole powerhead.
  1. Melted piston
    By Greggw/2g's in forum Technical Discussion
    Last Post: 02-21-2010, 03:06 AM
  2. melted #1 piston
    By 2.4 in forum Technical Discussion
    Last Post: 01-20-2008, 12:01 AM
  3. Melted Piston
    By jrpromax in forum Technical Discussion
    Last Post: 10-06-2004, 10:51 PM
  4. melted piston
    By nacimientobound in forum Technical Discussion
    Last Post: 07-14-2004, 07:38 AM
