Results 21,241 to 21,255 of 27932
Thread: Mercury Through The Years...
03-07-2021, 01:45 PM #21241The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
03-07-2021, 01:46 PM #21242The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
03-07-2021, 01:46 PM #21243The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
03-07-2021, 01:47 PM #21244The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
03-07-2021, 05:13 PM #212458000 RPM
- Oct 2011
- Southern California
- 3,569
- 179
- 471
- 3405
- 2330
- 29 Post(s)
Number Six Outdrive skill set.
The elder statesmen and acknowledged guru of the performance sterndrive, John Klumpjan started in 1968 with Carl Kiekhaefer and his company Kiekhaefer Aeromarine.
He was assigned to assist engineer Larry Lohse, who would be instrumental in developing the first Speedmaster drive (the Speedmaster III). As the company introduced the Speedmaster IV and V, more race teams were using them and they only wanted one guy to rebuild them when that time came — that guy was Klumpjan.
“I have 16 world championships and eight of those were with Aeromarine,” said Klumpjan who is now 70 years old. Among the teams/owners that demanded that Klumpjan rebuild their drives were Jerry Jacoby of Ajac Hawk fame, Dr. Bob Magoon, Tom Gentry, Don Johnson, Bob Saccenti, Craig Barrie, Bernie Little and Renato Della Valle, whom Klumpjan referred to as “The Italian Donald Trump.”
“The key to doing an outdrive right, whether if it’s a 6 or an 8, is setting the gears to the horsepower and torque,” said Klumpjan. “It’s more important than ever because of the horsepower being created.” He believes that the Dry Sump Six is actually easier to work on than the Speemaster III, IV or V because of the immense size of all the components.
The most critical part of the rebuild in his eyes is properly loading the spur and helical gears before making the final settings. He does disagree with some of his colleagues that the upper gearsets are often the first to go in a Number Six. “The only reason it would go is if something plugged the oil from getting to the upper,” he said.
He said that the most important thing owners can do to extend a Number Six drive’s life is to keep up with oil changes. After the first 25 hours, or break-in, oil should be changed every 50 hours.
PRA publication
John K.
Dave Strong liked this post
03-07-2021, 05:21 PM #212468000 RPM
- Oct 2011
- 3,569
- 179
- 471
- 3405
- 2330
- 29 Post(s)
Dialing in a Number Six Outdrive properly.
“Everybody wanted to build engines or do electrical or rigging,” said Matt Gilvey. “Nobody wanted to do sterndrives because they were afraid of them. People don’t understand setting up backlash or bearing preload.”
Gilvey teamed with Klumpjan at Doller Marine in 1988. From the start, he worked on Speedmaster III and IV drives. “The Number Six came out around 1990 and Gilvey received the Mercury Marine Master Technician Award in 1993.
Gilvey said that upper gearsets take the most abuse, depending on how hard owners are on their equipment. Like his compatriots, he said that the biggest concern he has when he rebuilds a Number Six is setting the load on the two spur gears. These are the gears that sit atop the two vertical shafts in the gear case. If you don’t get the load evenly balanced between the two, the engine’s power won’t be distributed evenly. This can shorten drive life.
Brian Jackson (former student of John Klumpjan) said that in addition to setting the load on the spur gears correctly, the pinion height and the shimming of the gears become critical when engines are putting out 1,500 hp. He said that the biggest factors in determining how often drives need to built are the power running through them and how hard the operator is on the equipment.
PRA publication.
03-07-2021, 08:23 PM #21247The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...Larry Lohse, Tom Theisen & Fred Kiekhaefer designed, tooled & built the first (#6)Keikhaefer Drive in 1987. They introduced it privately in a Miami hotel room to prospective serious customers during the Miami Boat Show in Febuary of 1988, under the company name Drives By Kiekhaefer. By the end of 1988, they were installed on a couple of well knowns offshore boats with big power & winning races. Later, in 1990, with the Mercury Hi-Performance/Kiekhaefer merger, the K-Drive was renamed the Number Six drive. The first Number Six dry-sump drive came in 1995...
Mark75H liked this post
03-08-2021, 11:48 AM #21248The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
Mugs914 liked this post
03-08-2021, 01:15 PM #212497000 RPM
- Dec 2005
- 2,124
- 642
- 288
- 1920
- 949
- 3 Post(s)
03-08-2021, 06:15 PM #21250The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...yes gene, the yo-yo blocks came out for the first generation, non-crescent, number three ssm. great idea at the time. you know i was referencing the introduction of the new, at the time, number six drive above, right?...
03-09-2021, 06:31 PM #21251The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...some of the very first K-Drives (later named number six drives) installed on Tom Gentry's Scarab...
GENE LANHAM liked this post
03-09-2021, 09:05 PM #21252Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
03-09-2021, 10:29 PM #21253The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...originally commissioned to build in 1993 this is a photo of fred's 42 comanche transom...with its original rigging & exhaust/muffler system he designed...
03-09-2021, 10:32 PM #21254The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
..."you have to be confident in your equipment if your going to paint them the color of lemons"...fred kiekhaefer...
03-10-2021, 01:58 PM #21255The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
..."just over the line"...fred kiekhaefer...
Mercury racing line-up thru the years
By triplestroker in forum Outboard and Racing HistoryReplies: 13Last Post: 05-08-2014, 04:31 PM -
What years were 2.4 & 2.5 blocks built by Mercury?
By Knothead in forum Technical DiscussionReplies: 28Last Post: 06-18-2013, 06:22 PM -
1976 Mercury 65 hp first start in 12 years
By DaveS8984 in forum Technical DiscussionReplies: 8Last Post: 07-26-2011, 06:07 PM -
Looking for an old Mercury commercial, about 10-11 years old
By Ron V in forum General Boating DiscussionReplies: 0Last Post: 04-27-2006, 08:31 PM
