Results 1 to 3 of 3
12-03-2015, 12:50 PM #1
info wanted on a yamaha 200hp 1997 VMAX
I am looking at buying a used 20" 1997 yamaha 200hp VMAX model P200TLRW It is listed' "LIKE NEW" from a dealer Its for my Hydrostream V-KING which is rigged for a mariner/mercury. Is this a true 200hp and will I need to re-rig it for the hyrdostream?
12-12-2015, 10:58 AM #2
It is a bass engine that should push the hp envelope.
You will need to re-rig, but it is simple:
Adapters from Mercury to 33c cable for throttle and shifter.
I think Merc throttle is pulling, while Yamaha throttle is pushing - check if your foot throttle supports both.
Gauges and overheat alarm need to be hooked to the corresponding connectors on the Yamaha.Markus' Performance Boating Links:
12-12-2015, 11:08 AM #3
Thanks holding off on buying a motor till spring. Having the v king painted over the winter.....
NEW Yamaha 4-Stroke VMAX Specs and info
By Brian Harden in forum General Boating DiscussionReplies: 48Last Post: 11-26-2009, 04:40 PM
