Results 1 to 6 of 6
Thread: Need help identifying a 2.5
11-16-2015, 07:31 PM #1Junior Member
- Sep 2015
- Huffman Tx
- 19
Recently got a 2.5 powerhead in a trade. Looks identical to several other Mercury racing 2.5 i have owned in the past. Cowling and intake horn. Trying to identify HP. Title lists as a 96 yr model but not HP. I know it had the top ball bearing on crank.I was told that only a few yrs had the top ball bearing on crank. What yrs was that? Also are the any numbers on the block that may list Hp rating? What should i look for?
11-16-2015, 08:59 PM #26000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
Looks like a 2.5 260 in the first pic. Cowl would match as well. The engine pic with the heads look like a 245 since it has bleed line fittings.
11-17-2015, 10:18 AM #3Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
It's not a 96 model but that's about all you can tell from that picture of the block lying there. It could be a 260, 280, or a Drag. You need to do two things. See if gasket heads fit it without modifications. Take a picture of the exhaust chest. Those two things will tell you what it is definitively
Erik Kiser
tux974 liked this post
11-17-2015, 07:19 PM #4
Looks like the motor tgreen had forsure on fb. Was suspose to be a drag
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
11-17-2015, 10:20 PM #5
first one check alt. bracket for threads.. along with what eric said.. no threads probably drag.. threaded might be late 260? ('bout '98) or 280... second is 150 or 200 promax....
tha big bearin' came out in '96 i think but don't think tha 260 ever had tha alt. bracket stuff like came out on tha first 280 but thats with lotsa "coffee stained" brain cells, so........Last edited by tlwjkw; 11-17-2015 at 10:55 PM.
11-18-2015, 08:39 AM #6Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Many late 97 Drags had the alternator bosses tapped. Who knows why Mercury did it. 98 model 260's had the alternator bosses but retained the same exhaust chest as previous 260's. The exhaust chest picture will tell the difference between 260 or 280/Drag. Once you narrow that down the head bolt spacing tells the rest of the story
Erik Kiser
tlwjkw liked this post
Mercury Tech: help identifying a v6
By whatsamerc?? in forum Technical DiscussionReplies: 10Last Post: 07-14-2014, 06:01 PM -
Mercury Tech: Identifying this 200?
By Jacob in forum Technical DiscussionReplies: 20Last Post: 07-28-2009, 10:20 AM -
Need help identifying LU
By backinblack in forum Technical DiscussionReplies: 1Last Post: 12-24-2008, 02:45 PM -
Identifying 235 OMC
By kris_tx in forum Technical DiscussionReplies: 3Last Post: 06-23-2004, 11:07 PM -
Need help identifying....
By sosmerc in forum Technical DiscussionReplies: 2Last Post: 03-29-2003, 05:58 PM
