Results 1 to 15 of 20
Thread: Reed Cage bolts stripping
10-31-2015, 08:35 PM #1Member
- Mar 2013
- mobile Al
- 92
- 14
I purchased some reeds a while back and started pulling the old ones off today.
I have the correct tool and size bit but I am stripping the heads off of several of them. On whole side of one are all stripped. Any idea how to get them out etc etc
Promax 225hp 7 pedal.
10-31-2015, 08:53 PM #25000 RPM
- Mar 2006
- auckland new zealand
- 655
- 9
- 13
Have you broken the heads off? or just rounded the drive in the top?
10-31-2015, 08:53 PM #3
try to grab them with needlenose vice grips,i would use some heat source too
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
10-31-2015, 08:54 PM #4Member
- Mar 2013
- mobile Al
- 92
- 14
Not broken. Just rounded
10-31-2015, 09:43 PM #5
Try heating em up with a solding gun....
Really small pair of channel locks
Dat don't work....get grinder on em....I had to grind a few last time81' HYDROSTREAM VECTOR / slightly Modified 200
10-31-2015, 09:45 PM #6Member
- Mar 2013
- mobile Al
- 92
- 14
Not sure the heads are large enough to use some voce grips etc. They are pretty small.
10-31-2015, 09:50 PM #7
I feel your frustrations
10-31-2015, 10:04 PM #8Member
- Mar 2013
- mobile Al
- 92
- 14
How did you get the screw out after you bringing them?
10-31-2015, 10:15 PM #9
After grinding head off...reed comes off over screw...then from the heat usually can unscrew whats left by hand...
Slimm liked this post
11-01-2015, 02:51 AM #10
Heat and vice grips like the guys say.
11-01-2015, 07:42 AM #11
Two things,be sure you are using the proper fitting bit.There are many now days that are close but not right.Last take a block of wood mount the cage to it,put it in a drill press,and with a long bit use the down pressure to hold the bit while turning the spindle with a large pair of vice grips.
11-01-2015, 08:13 AM #12
Where do you get new screws?
What locktight do you use to reinstall?
11-01-2015, 08:28 AM #13
Screws,Fasin all, aircraft spruce? I usually have a few donor five petal cages laying around.Blue lock tite,and don't over tighten,you can deform your new reeds!
11-01-2015, 08:46 AM #14Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
propane torch with small jet tip like plumber uses and vice grips i cant count how many ive removed like that the loctite is doing its job the heat will make it get loose fast just dont get carried away
11-01-2015, 09:03 AM #15
use tha heat ta start and ya won't have tha screwin' up problem......most of tha time you can "hear" tha loc tight turn loose...
2.4 reed cage
By HEAVYBULLET in forum Parts WantedReplies: 2Last Post: 07-21-2013, 10:24 AM -
Who has seen a reed cage like this
By Ripnfool in forum Technical DiscussionReplies: 18Last Post: 09-17-2009, 09:55 AM
