Results 1 to 12 of 12
    Apr 2013
    Lexington, ky
    Should I use head studs on my 99 2.5 200
    When I go back together with my engine should I use head studs? I have been popping heads off and checking wash, then swapping between two sets of heads with different CC depending on what I am doing. I am fearful of pulling threads out of the block and curious what the common consensus on using studs are.
    Anyone have a part number?
    Slimm
    Ft. Lauderdale, Fl
    Studs are a good idea if you are popping them off and on regularly.... blue loc-tite to hold them in....
  3. Thanks Slimm thanked for this post
    Likes Slimm liked this post
    Dec 2012
    HUDSON, FLORIDA
    The problem is not so much stripping the threads out. A head bolt stretches thats gives you clamping force they can stretch .006" 3 times max and trash em. if your gasket compresses .005 your bolts not really working ask any race engine builder art x s\p drag sbc builder. if you use studs, use loc tite or jb weld, get all the studs in, slide the head over the studs "no gaskets" and torque the head down to about 25 pounds and leave it over the sit over night. thats called perfect perch. make that 20 ft lbs
  5. Thanks Slimm thanked for this post
    Sep 2010
    Ft Worth, TX
    I'm also trying to find head studs as well for my 2001 2.5L. Anyone have a source?
    SE MN
    Brendan Powers gets 325.00 a set. Something tells me there is a more cost effective alternative. Luckily my motor had them when I bought it.
    Dec 2011
    Ludington michigan,on the shore
    Quote Originally Posted by CNC_Guy View Post
    This is what I do on my steel bore engines with great success.Zoro part # G1642042 3/8x16x6' grade B7 alloy 120psi tensil C35 Rockwell threaded rod,I cut to length, finish ends and lock tite in place.It is no different than the merc head bolts that are all threads.Ive cycled these at least 15 times on one engine,also use hardened thick washers and grade eight nuts,no locks,a drop of blue LT,standard tork.About $30 per engine.
  9. Thanks Slimm thanked for this post
    Likes texasvector, Slimm, rgsauger liked this post
    Thebes, Il.
    Outasite, If you wouldn't mind check out this link to Fastenal and see if this rod is the same or better than what you have been using please.
    https://www.fastenal.com/products/details/47454?searchmode=filterByInMyStore&r=~|categoryl1:%22600000%20Fasteners%22|~%20~|categoryl2:%2260016 9%20Rods%209and%20Studs%22|~%20~|categoryl3:%22600173%20Threaded%20Rods%22|~%20~|sattr02:^3/8%22-16$|~%20~|sattr11:^%22125000%20psi%22$|~%20~|sattr06:^Plain$|~
    Dam , that's hell of a link. lol. Lets try this, below is description, etc.
    3/8"-16 x 6 ft ASTM A193 Gr B7 Plain Threaded Rod
Name:	Fastenal head stud rod.PNG
    Thanks for your help and hope this helps other in a more economical head stud for lake motors.
    Sep 2006
    Key Largo, Fl
    We sell sets for 2-0-2.5 for 125$ a set,in stock,Chris
    Dec 2012
    tn
    Grade B7 rod is what we use to hang overhead cranes - The 5/8" diameter goes for about $2.50 a linear foot at local fastner distributor (Not a Fastenal) Normally in 3' or 12' length. 3/8" should even cheaper. In Nashville we get it at Action Bolt and Screw-
    Given the amount of work in prepping the qty involved- this is probably a pretty good price "We sell sets for 2-0-2.5 for 125$ a set,in stock,Chris"
    Dec 2011
    Quote Originally Posted by redstv169 View Post
    Looks like the same grade,The rod that I use has a gold looking coating that seems not to rust.
  14. #11
    Thebes, Il.
    Yep, I think CCM deal is a deal when it comes down to it for the average guy. I'm still on fence but Chris's price is right in line for my budget and I don't have to dress threads or do anything extra. Thanks all of ya, love the input and different points of view this site provides.
    Apr 2013
    Lexington, ky
    Here is the studs I purchased from Grainger. They were the perfect length and I have checked them every time I have been out and haven't had any lose torque yet.
    http://goo.gl/K5GIZp
    https://www.grainger.com/product/GRA...tics=altItems#
    Slimm
  16. Thanks texasvector thanked for this post
  1. Head studs
    By eddieneal1292 in forum Parts Wanted
    Last Post: 11-03-2013, 07:29 PM
  2. OMC Tech: Head studs
    By lokinutz in forum Technical Discussion
    Last Post: 11-09-2010, 08:31 PM
  3. head studs
    By hosejockey4506 in forum Technical Discussion
    Last Post: 05-29-2008, 08:24 AM
