Page 1 of 42 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... LastLast
Results 1 to 15 of 622
    Rhode Island
    Who in their right mind restores a BAYLINER?!
    *****EDIT ---> Project started October 2015... Winterized after 4 motors and 3 rebuilds October 2016***
    Well, it's a 1997 BAYLINER Capri 1401 LS. Bought it off craigslist for $300! The galvanized trailer alone is worth that, so I took her home.
    Started pulling good parts out like controls, steering, wiring, and got carried away!!!
    Plans- fiberglass the inside, quick paint job inside and out, a couple seats, and put a 50hp merc I have in the garage on it. Maybe next year throw a bigger motor on
    its only 14' and already has a pad on the bottom. Good deal!
    ****2018 EDIT ****
    Boy did that plan above not work out. Opened up a can of worms.
ID:	371893Click image for larger version.
ID:	371895Click image for larger version.
ID:	371894Click image for larger version.
ID:	417400Click image for larger version.
ID:	417401Click image for larger version.
ID:	417402Click image for larger version.
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg   image.jpg
  2. Likes afr, Slimm liked this post
    Rhode Island
    Started pulling it apart. Found some plywood dropped in by a prior owner, secured with liquid nails and drywall screws!!! Also looks like someone attempted to START removing the gas tank and gave up.
  4. Likes afr liked this post
  5. #3
    Apr 2007
    i would do that no problem thats how i got all my boats / just plane ole good hard work
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
  6. Likes hydrostreamvking4m liked this post
  7. #4
    Rhode Island
    Might as well keep ripping it apart! BAYLINER didn't leave any drain holes for the sides- took out about 5 big trash bags full of soaked foam.
    got the tank out and found out why someone had tried to remove it! Big ol' HOLE in the bottom corner. Makes the gas tank useless...unless you're a welder like me!!!
    Rhode Island
    Sure enough, rotted transom too. Got it out with a simple pry bar. Then smashed my face with said prybar. Oops.
    Another crappy design of BAYLINER--- the top of the transom was never even glassed in! The top half of the hull just sat on top of it, and some angle bracket screwed in. Horrible design. It will be getting glassed in when I put it back together.
  9. Likes afr, hydrostreamvking4m, MegaBaron liked this post
  10. #6
    Rhode Island
    Tear down complete! Grinding and sanding is 99% done. Time to rebuild!
  11. #7
    Dec 2001
    Sunbury, Pa
    It looks like your girlfriend passed out in the first picture when she saw you brought home another project.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
  12. Likes David - WI, CNC_Guy, FMP liked this post
  13. #8
    Apr 2013
    Lexington, ky
    Subscribed. Have you made a decision on materials yet?
    Slimm
  14. #9
    Rhode Island
    Quote Originally Posted by Riverratt View Post
    hAHAHA I didn't even notice that until now.
    Quote Originally Posted by SlimmDaddy View Post
    Slimm
    Yea - Expensive stuff is going towards my tunnel hull. This guy is just getting the plywood treatment. I'll use some solid planks for the stringers, but the bulkheads, seat boxes, and floor will be plywood. I'm thinking either 5/8" or 3/4" for the floor. A layer or two of 6oz 50" wide cloth to seal it all.
    Where there was a huge puddle in front of the tank in some of the 1st pictures, I'm going to put a hatch in the floor - Keep access in there for some storage / and to ensure things stay dry.
    Still looking for some cheap seats to bolt in.
  15. Likes Slimm liked this post
  16. #10
    Rhode Island
    Stringers and bulkheads are done. New Aluminum tank welded up, decided old one was too SWISS CHEESE to restore. Ready to cut floor pieces out, and start fiberglassing everything in. I'm going to make a false floor cover over the tank so I can remove it for inspection, and another in the fwd section for storage (ancor/rope/empty beer cans etc).
    Boy did I open a can of worms. I need to get back to working on my tunnel hull ! ! !
    Attached Thumbnails Attached Thumbnails IMG_2791.jpg   IMG_2851.jpg   IMG_2853.jpg
  17. #11
    Damn good eye! And that made my day! Friend mine has a 'Liner like that! Nice little boat!
  18. #12
    I thought she was part of a custom swim platform!!! Gary
  19. #13
    Lemonade, good job. Pad hull to boot. Hang something decent on it. Leave that 50Merc in the garage, find a good low hour late 90's 120 FORCE , lots around for decent $ and surprise yourself. You'll get hundreds of hours out of it if you stay on top of the tuning and maitenance, and good mpg and mph with the right prop.
    I just took another look , for sure add a couple of knees and hang a 120 on it. FUN
  20. #14
    Rhode Island
    She's definitely a fun platform
    I'll keep an eye out later this winter / early spring. I could just sell this motor for some $ to replace with a bigger spinner
  21. #15
    Rhode Island
    Starting to finish up the deck. I should have made it simple and just put a solid sheet down. Nope, had to get complicated and add storage bulkheads and doors haha.
  22. Thanks SW6764 thanked for this post
  1. Never mind Quints
    By Wayne Cammidge in forum General Boating Discussion
    Last Post: 02-19-2015, 05:29 AM
  2. Mind if I vent?
    By QUICKSILVER in forum The Scream And Fly Lounge
    Last Post: 10-21-2003, 10:22 PM
  3. Keep An Open Mind
    By mr.clean in forum The Scream And Fly Lounge
    Last Post: 10-09-2003, 12:23 AM
  4. Tell me if I'm out of my mind!
    By cdaspeed in forum Props, Setup, and Rigging
    Last Post: 08-26-2003, 09:31 AM
