Results 1 to 10 of 10
09-10-2015, 10:38 AM #1
15" 2 Hole CLE Lower, 15" 4 Hole Lower, 25" 2 Hole Lower, CLE Case - Cleaning House.
Up for sale is this 15" CLE Lower with a 1.87 gear. I bought a running Rabco for the parts and this is one of them.
This lower was the previous owners "spare" I was told it worked fine but with any used part I would recomend the
lower be checked and seals replaced. The impeller is missing and the upper oil level plug looks to have a repair done to
it also.
Asking 1150.00 - plus freight
*Need more pictures? Just ask... thanks
09-10-2015, 10:41 AM #2
Up for sale is this 15" 4 hole CLE Lower with a 1.87 gear. I bought a running Rabco for the parts and the tear down has started.
This lower is still on the engine (*also listed) It shifts smooth in and out of gear and pushed the little boat well into the 90's
Asking 1550.00 - plus freight
09-10-2015, 10:44 AM #3
Mercury 25" 2 Hole CLE Left Hand Lower / 1.87
This was bought for the Left Hand parts, I was told from the member I bought it from that it worked fine. but with any used part I would recommend the
lower be checked and seals replaced JUST TO BE SAFE.
Asking 500.00 - plus freight
09-10-2015, 05:28 PM #45000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
09-10-2015, 05:30 PM #5
Ratchet? Not sure what you mean by that.
09-10-2015, 05:34 PM #65000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Can you spin the prop shaft one direction when it is in gear and hear a clicking sound? Or will it not free wheel except in neutral?
09-10-2015, 05:36 PM #7
Not sure on how I can check that with it on the motor, I'll have Gary check it at the shop and let you know. .
09-10-2015, 05:38 PM #85000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
just turn the prop with it in gear and see if it will turn one way or another. Motor not running of course!
DaveLast edited by CNC_Guy; 09-10-2015 at 06:20 PM.
09-11-2015, 02:23 PM #9Member
- Aug 2014
- michigan
- 84
cnc_guy it is a ratchet lower not a crash box style and the drain plug is in the center below the prop shaft hope that helps gary
09-11-2015, 04:48 PM #105000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Yes it does, thank you.
DaveDave
Complete Mercury 2.5L 2 hole CLE lower - LH / 25" $600.00
By Pachanga_rick in forum Lower UnitsReplies: 4Last Post: 08-21-2015, 12:09 PM -
20" CLE lower 2:1 gears 4 hole
By Csmyj in forum Lower UnitsReplies: 2Last Post: 02-13-2014, 02:39 PM
