Results 1 to 7 of 7
09-10-2015, 07:31 AM #15000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Merc 2.5lt carb 2002 "loads up" at idle and dies?
Merc 2.5lt 2002, CDMs, carbs- Overall motor runs great, starts from cold reasonably quick, good throttle response thur power ranges.
After a 5-10 mile run when I come off plane and go to netural idle- it sounds good and idles smoothly. After a time of idling in netural- maybe 5 minutes- it begins to lose RPMs and runs progressily rougher- has a cough or two and eventually dies. Refires fine if throttle is advance- with throttle fully returned- start/die start/die. I go a little heavy on the oil- but not excessive.
Fuel pump and carbs and been built within last 10 hours- it did same before these were built.
Suggestions please !!
09-10-2015, 08:53 AM #2
Have you adjusted the idle as described in the service manual. The cough you describe may be lean pop. There are idle adjustment screws for each cylinder on the carbs and if memory serves, you start with them at 1 1/2 turns from lightly seated, warm up the engine to operating temp. then with the engine in gear idling (should be ~ 700 RPM), you adjust them in small increments until the cylinder stumbles then back it out 1/4 turn. Get the service manual and check this procedure, I may have something wrong....but you get the idea.
Go Time
26 Regulator twin 250 EFI
09-10-2015, 08:58 AM #35000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
I figured other way around- too rich- loading up- I have a hard time detecting the "stumble" on 6 cylinder engines- good easy starting point for sure
09-10-2015, 09:07 AM #4
If it gets worse as the weather gets colder...it's a good indication that its on the lean side.
Go Time
09-10-2015, 06:44 PM #55000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
Thermal Air Valve may be stuck closed
09-11-2015, 05:54 AM #65000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
It was an easy fix- turned all idle screws richer 1/4 turn- she will sit and putter all afternoon now- thanks
09-11-2015, 06:14 AM #7
There you go....
Go Time
Merc 175 EFI wont idle...? Just dies...
By Bartman39 in forum Technical DiscussionReplies: 0Last Post: 08-19-2007, 07:23 PM -
Need help adjusting WOT, IDLE, and TIMING "1984 200hp merc"
By blachermeier in forum Technical DiscussionReplies: 4Last Post: 07-08-2007, 07:33 PM -
Larry "Bud" Melman dies at 85 "Calvert DeForest"
By The Big Al in forum The Scream And Fly LoungeReplies: 0Last Post: 03-24-2007, 05:12 AM -
98' 225 johnson venom loads up, won't idle
By fofiveoh in forum Technical DiscussionReplies: 2Last Post: 04-10-2005, 09:25 PM
