Results 1 to 4 of 4
Thread: optimax battery cables
09-06-2015, 04:35 PM #1Junior Member
- Aug 2015
- Maryland
- 7
Long after I had gotten my Utopia 185 with Optimax 200 engine back from the dealer (now out of business) I noticed that two small wires were not connected to the battery. One is green and appears to head off to port under the rear seat. The other is black with a protective corrugated wire loom around it and is bundled with other wires down in the bilge. Can anybody tell me what they're for and what posts to connect them to? Thanks.
09-07-2015, 01:25 PM #27000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
it might be the fuel/temp/?? wires from the smartcraft wiring.
09-07-2015, 04:33 PM #3Junior Member
- Aug 2015
- Maryland
- 7
The other end of the green wire is connected to the fuel filler inlet inside the hull topside. I presume it's a static ground and should be connected to the battery negative pole. Does that make sense? I have pix, but can't figure out how to upload them. Nothing happens when I click the "manage attachments" button.
Thanks.
Turned off popup blocker. Here are pix.Last edited by Navy Bob; 09-07-2015 at 05:03 PM.
09-07-2015, 10:52 PM #4
Actually, the wire from the filler neck should go straight to the fuel tank ground tab if it's an aluminum tank or to the fuel sender ground. Then the tank is grounded to the negative side of the battery..... at least that is how it should be done, going to the battery with that wire is ok, so long as there is a direct wire coming from the fuel tank as well.
Mercury Tech: Battery cables.
By DryMartini in forum Technical DiscussionReplies: 2Last Post: 09-18-2014, 11:10 PM -
Battery Cables & Isolaters
By eli in forum Misc. Parts and AccessoriesReplies: 0Last Post: 09-08-2014, 10:55 PM -
battery cables
By j90 in forum Technical DiscussionReplies: 4Last Post: 07-20-2010, 08:38 PM -
Battery cables to everything.
By Karl817 in forum Technical DiscussionReplies: 10Last Post: 07-04-2003, 04:33 PM
