Results 1 to 12 of 12
09-06-2015, 03:44 PM #15000 RPM
- Oct 2002
- tappahannock, va
- 741
Lost fuel pressure ,fuel coming out of number 6 cylinder
1999 Mercury 300 pro max, was running down river fine, then slowed down and cut off. Pumped primer bulb up and got back end. Pulled spark plugs and checked fuel pressure -none. Pumped primer bulb tight , turn key on no fuel pressure, hear pump running ,crank motor over without spark plugs, fuel is pumping out of number 6 cylinder
09-06-2015, 05:00 PM #2
may have spit the tip off that injector
09-06-2015, 05:02 PM #35000 RPM
- Oct 2002
- tappahannock, va
- 741
What would cause #5and #6 injector to spray fuel wide open. Motor isn't even running , key in the on position ,injectors steadily spraying
09-06-2015, 05:04 PM #45000 RPM
- Oct 2002
- tappahannock, va
- 741
Just had injectors clean 2months ago by brucati
09-06-2015, 05:42 PM #5Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
pintel stuck open
09-06-2015, 06:16 PM #6
Unplug them and see if they still keep spraying
09-06-2015, 09:32 PM #7Member
- Feb 2006
- Michigan
- 56
- 35
- 122
- 30
Had a 250 3l efi years back with the same problem. The ground for 5 and 6 in the fuel ecu stuck closed. Replaced the fuel ecu all good.
09-07-2015, 05:27 AM #8
you have the promax with the laser style intake?
O ring leakage? ( fuel rail)
maybe got damaged when assembling
09-07-2015, 07:04 AM #95000 RPM
- Sep 2005
- Bensalem, PA
- 281
Ohm your injector harness. If you disconnected the plug for the injectors does it still lose fuel pressure . If they are good pull the front of the intake off. Either the orings for the injectorsare bad or a pintle is stuck or orings for the fuel lines are bad.
09-07-2015, 01:24 PM #105000 RPM
- Oct 2002
- tappahannock, va
- 741
I discounted the fuel injecter harness and it stops spraying. I'll check the harness but I got a feeling it's the fuel ecu.
09-07-2015, 04:15 PM #11Checkmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
09-07-2015, 06:24 PM #12
I had same problem with a 300 pm. It was the fuel computer...
Cawley
Do I need to run a fuel pressure regulator with a Holley Red fuel pump?
By Steve2ManyBoats in forum Technical DiscussionReplies: 14Last Post: 03-31-2011, 08:09 AM -
OMC Tech: OMC LOOPER FUEL PRESSURE:output on fuel pump / vapor separator is not steady (< 3PSI)
By foca1 in forum Technical DiscussionReplies: 5Last Post: 06-01-2010, 06:48 PM -
Recommended inline fuel filter and fuel pressure regulator
By topkick in forum Technical DiscussionReplies: 2Last Post: 09-20-2005, 09:25 AM
