Results 1 to 5 of 5
    Rev limiter question 3 cyl 1995 60hp evinrude
    can someone please tell me at what rpm the limiter comes in on a 1995 evinrude 60/70hp.
    this is the later of the 3 cylinders with oval ports and quickstart and S.L.O.W function built in.
    its an original fitment from factory that I need to know about, not a aftermarket one.
    sweden
    that info was for the older bridge port 56cu in motor.
    mine is the oval port with totally different ignition system.
    I am not finding much info on this engine at all.
    London,Canada
    6700 limit
    thanks little charger.
    would you think the horse power runs out at 6,000 or 6200 ? or does it still climb with the revs ?
    I know its a dodgy question , but I am slowly getting more speed with my TUG.
  1. when does the rev limiter kick in 1995 60hp evinrude triple
    By phillnjack in forum Technical Discussion
    Last Post: 05-28-2014, 07:50 AM
  2. Replies: 11
    Last Post: 10-11-2012, 07:50 PM
  3. OMC Tech: 1995 Evinrude 112, rev limiter??
    By 200valeroyt in forum Technical Discussion
    Last Post: 05-13-2011, 12:56 PM
  4. 1995 Evinrude Intruder 175 question
    By CyCleZ2004 in forum Technical Discussion
    Last Post: 04-06-2011, 06:23 PM
  5. 1995 260 rev limiter.
    By chad202 in forum Technical Discussion
    Last Post: 08-23-2005, 02:35 PM
