Results 1 to 3 of 3
Thread: 300x clamp bracket free play?
08-16-2015, 08:00 PM #15000 RPM
- Feb 2004
- 122
- 20
- 12
- 85
- 61
Where the pivot pins go through the transom bracket and into the trim cylinder I have maybe a 1/16 of an inch free play when I lift the mid section up replaced all the bushing still there? Anyone else have this problem?
Thanks
08-16-2015, 08:48 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,640
- 606
- 920
- 1698
- 7137
- 3 Post(s)
They all do, this is what causes exhaust housings to break. All of the load gets put on the top bolts, they break, and then the play causes havoc. Charlie (Chaz) here on the board, has the cure and will preload the housing so that there is even support being applied by the top and bottom mounts along with shimming it correctly. This eliminates all of the slop and makes for much more consistent water pressure.
noli thanked for this post
08-16-2015, 10:03 PM #3
Yes , Joe is 100% correct . The "Slop Stop" does away with all of those issues !
Thank you Joe ...
WTB 300X Offshore Clamp and Swivel bracket
By hydroo in forum Parts WantedReplies: 0Last Post: 09-11-2013, 08:13 AM -
Mercury Tech: help with 2.5 offshore clamp bracket swivel bracket assembly
By davidmercury in forum Technical DiscussionReplies: 6Last Post: 05-04-2011, 06:59 AM -
Weight of a Merc 300X Mid & Clamp Bracket??
By Hydrogasm in forum Technical DiscussionReplies: 5Last Post: 04-01-2010, 10:31 AM
