Results 121 to 135 of 164
Thread: V-king YT re core mystery
05-31-2016, 06:42 PM #121
stringers are all bedded and glued in. Once they set up i removed my 2x4 spacers.... before the seat boxes where glued down with cabosil, i glassed the stringers in where i knew i could not reach again. 1708 is next. All stringers and seat boxes where completely sealed with resin. Starting to see the light at the end of the tunnel now.Last edited by Erik C; 06-01-2016 at 04:32 AM.
streamteam liked this post
05-31-2016, 07:44 PM #122
I have to ask. Maybe I missed it somewhere but is that plywood strips in the back pad area there? If so why plywood and not balsa core?
-Kevin
1982 Hydrostream Vector
1982 Hydrostream Vamp
1973 Hydrostream Vixen
05-31-2016, 09:07 PM #123
You are correct, it is plywood planking. That is where this whole "V-king mystery core" thread started. I have never seen the planking before. After ripping my boat apart and doing some research I have learned that it was a layup process that people did use.... From what I read kind of old-school. Anyways mine was in good shape, and still bone dry so instead of taking the chance of damaging my pad....I left the planking in place and used balsa everywhere else. I'll tell you that is one bulletproof pad.
Hippie459MN liked this post
05-31-2016, 10:23 PM #124
Right on. That is odd though. Someone at one time must have been in that thing cause I have never seen a hydrostream come from the factory that way. Def interesting.
-Kevin
05-31-2016, 10:37 PM #125
For sure, I still am puzzled how it ended up there. All the glass work / core / ski locker, all looked original. A few guys on here along with me think it may have been sent back to Hydrostream at some point for pad work? We may never really know.
06-01-2016, 05:52 AM #126
Man...That is some great woodwork !!!
If your ever down near TN, I would sure like some help with my V-King !!
Just kidding, really nice quality work happening there..
JamesJames H. W2F a V-King... Want 2 Fly a V-King
06-03-2016, 04:53 AM #127
loop, streamteam liked this post
06-03-2016, 07:22 AM #128
looks great!
I became a big fan of 1708 and hull and deck putty. Gave me almost "professional" results.lol
For the more complex curves I found you could wet your pre-cut 1708 pcs with acetone,mold it to fit and let dry in place. It would hold the shape really well and make it easier to install with resinlimited skills
Erik C thanked for this post
06-03-2016, 07:30 AM #129
That sounds like a great tip... I had a heck of a time getting it to wet out and bend around all those curves. Once it was saturated with resin it formed easily, so that acetone trick sounds great. I had to start at one side and spread it on like wallpaper pulling it tight as I went while wetting it out... I have learned a ton of info from you guys on here.
06-12-2016, 01:14 PM #130
Well, there's the basic layup. All that's left is 1708 over the transverse stringers and then some finish sanding. ..... Not sure what to call it? Comp YT? The only core that is in this boat is in the pad. Dare to be different is what I say. So after finish sanding do you guys have any tips on a good paint to use, maybe bilgekote?
06-12-2016, 08:59 PM #131
I used the gelcoat from Mertons. Comes in gallon cans, mixed it up and rolled it on. I messed
up the first time with the working time, probably had
to much hardener and it set up in less than 10 minutes. Once I mixed it lighter in the hardner it was much better to work with.
Epoxy would also good I would think.
06-13-2016, 06:08 PM #132
Looking good Eric, are you planning on weighing to see what it weighs
1987 V-King YT 200 Evinrude Vindicator
1998 16' Weers HPT Pontoon 60 Evinrude 36 MPH
06-13-2016, 06:27 PM #133
Thanks bob, I would love to weigh this thing.... It must have lost some serious weight... I'm guessing over 100 lbs? Total......no floor, wet foam in the sponsons,rotted core,bench seats,ski locker... Who knows maybe over 100? I cant wait to clean it up and get this thing wet.
06-18-2016, 06:26 PM #134
06-19-2016, 07:05 PM #135Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Your "deck wing attachment points" may cause cracks in the hull by putting pressure on small areas. I would put some core behind them. jm 2cts....
v king floor,core,transom
By roycesrolls in forum Fiberglass and Composites DiscussionReplies: 18Last Post: 09-17-2010, 07:50 AM -
V-king floor/core repair near orlando
By 200VEGAS in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 03-15-2010, 09:40 AM -
Mystery to me
By SDuster11 in forum Technical DiscussionReplies: 7Last Post: 09-15-2005, 10:42 PM -
Yet another mystery 260..
By RED ALERT in forum Technical DiscussionReplies: 21Last Post: 08-26-2003, 09:21 AM
