Page 6 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 76 to 90 of 164
  1. #76
    Jan 2005
    Shawano Lake
    Thanks Eric, Made some more progress, the knees and center core is done. Now it on to the floor and then the sponsons
ID:	334499Click image for larger version.
    1987 V-King YT 200 Evinrude Vindicator
    1998 16' Weers HPT Pontoon 60 Evinrude 36 MPH
  2. Likes tux974 liked this post
  3. #77
    Jul 2009
    Worcester ma
    Looking good bob, that will be one strong rebuild.... The real fun begins removing all the old foam from the sponsons.... I found if you start in one spot and get down to the hull you can than use a flat crowbar to pry it up in chunks.. A drywall saw also helps.
  4. #78
    Jan 2005
    Shawano Lake
    Thanks Eric for the tips on getting the foam out, I will get started later this week. If you have any other tips please let me know.
    Thanks Bob
  5. #79
    Winnipeg
    looks great bob, your boat is one of my favorites
    Allison XB02, 22ft Tritoon 225 4 stroke, two seadoo sparks
    Past rides 2001 STV EURO, Allison Grandsport, STV RiverRocket, STV Euro, STV ProComp, Hydrostream V-King
    RIP RPM RACING
    RIP GTS1
  6. Likes streamteam liked this post
  7. #80
    Aug 2004
    Venice, Florida
    Didnt read this thread until tonight and your past it but if you had wanted to remove the plywoood from that pad would a router set to the right depth have worked well? Just use the router to eat it up.
    21' Paramount
    Mercury 300 Promax
  8. #81
    Jul 2009
    Worcester ma
    Deameanor, thanks for checking out the thread. I never thought about the router idea, that would probably do the trick... after a bunch of back and forth questioning, and im sure not everyone will agree I ended up deciding to leave the wood planking in the pad. it was in perfect shape once i got all the old crap out of the boat. I did some research, originally i thought "who the hell Half Assed my boat" by putting wood planking in the pad instead of balsa.... but i guess its more of a "old school" boat builder thing. It doesn't rot like balsa, The pad can really take a beating and it has no flexing issues if done right.. so if your hull is blueprinted i guess its not a bad thing. i cant tell you the exact type of wood it is, but its not really plywood... its some type of planking? strips.
  9. #82
    Jan 2005
    Shawano Lake
    Well I have the foam out, to my disappointment there was only a little bit of the core wet on the drivers side, probably from the spot where my old speedo pickup was and got tore off years ago and the passenger side was completely dry, but I will be replacing it all as long as I have it apart. A person just don't know till you get it apart!!
ID:	335414Click image for larger version.
  10. #83
    Jul 2009
    Worcester ma
    definitely not wasted effort bob, now you know for sure what was in your sponsons. that was my biggest thing.... I wondered what was in mine for years. now that can be crossed off the list. are you putting ribs in or going with foam?
  11. #84
    Jan 2005
    Shawano Lake
    I am going to put a couple of ribs and the foam back in, I only removed about 5 feet of the foam. the pic's of the ribs look good.
  12. #85
    Jul 2009
    Worcester ma
    my garage warmed up to about 50 degrees so I finally started on my stringers. I have the tank, and seat boxes figured out... next will be where to mount my trim pump and battery. I can then coat all the wood in resin, before the glasswork in the spring. I also made some drain plugs out of SS for the sponsons.
ID:	336248Click image for larger version.
ID:	336249Click image for larger version.
  13. #86
    Jan 2005
    Shawano Lake
    Looking good Eric, the drain plugs look exactly like the one's my buddy gave me for the sponsons, SS too.
    Made some progress on mine too. I have the core back in the sponsons and the floor glassed down.
ID:	336299Click image for larger version.
ID:	336300Click image for larger version.
  14. Likes hydrostreamvking4m, D.ONEAL liked this post
  15. #87
    Jul 2009
    Worcester ma
    wow, looking good bob. I like how you tied the transom knee into the floor like that. looks very very solid.
  16. #88
    Jan 2005
    Shawano Lake
    I have the floor done and the tank mounted, ready to move on to the bottom touch up.
ID:	337679Click image for larger version.
ID:	337681Click image for larger version.
  17. Likes D.ONEAL, hydrostreamvking4m, Erik C liked this post
  18. #89
    Jul 2009
    Worcester ma
    Unreal!!... your putting me to shame here bob. last week it was -10 here so I wasn't even going to try haha. the boat is looking awesome. the recessed tank was a great idea. That must have took some careful measuring. that's also quite the rotary setup you have there for the boat. great work!!
    p.s. nice drain plugs
  19. Likes D.ONEAL liked this post
  20. #90
    Feb 2006
    Colchester, CT
    I missed this thread until now. I love the ride of my YT compared to a Vee bottom VKing I used to have. Here's a video of mine with a 2.4 225. Nice job with the rebuilds!
    https://m.youtube.com/watch?v=ik43qNElrBU
    A few boats starting with V's
    Hydrostream Vandal
    Hydrostream Vamp
    Hydrostream Vector
    Hydrostream Viking
    Hydrostream Verado
  21. Likes streamteam liked this post
  1. v king floor,core,transom
    By roycesrolls in forum Fiberglass and Composites Discussion
    Last Post: 09-17-2010, 07:50 AM
  2. V-king floor/core repair near orlando
    By 200VEGAS in forum Fiberglass and Composites Discussion
    Last Post: 03-15-2010, 09:40 AM
  3. Mystery to me
    By SDuster11 in forum Technical Discussion
    Last Post: 09-15-2005, 10:42 PM
  4. Yet another mystery 260..
    By RED ALERT in forum Technical Discussion
    Last Post: 08-26-2003, 09:21 AM
