Results 61 to 75 of 164
Thread: V-king YT re core mystery
12-12-2015, 09:33 PM #61
Here is your motivation over the winter:
Stock 225 promax + out of the box 32" lightning ET = 104 MPH on the limiter. Full interior boat used from everything from tubing to fishing.
http://youtu.be/UvinfQ5ZODs1989 21' Skater - twin 2.5s
1986 Cougar 21MTR, 15" 300XS - sold
2002 TUFF 21 (#0.1), 300xs - sold
1986 Valero YT, 225 Promax - sold
1987 Viper, 140 cross flow - sold
HornBoats liked this post
12-12-2015, 10:19 PM #62
Your right about motivation, I want to drop my boat in now as is haha. Great vid, I love the shots of the prop surfacing. I'll tell ya those YT hulls are no joke, full interior and your still seeing 104 mph.
12-13-2015, 07:55 AM #635000 RPM
- Jan 2005
- Annapolis, MD
- 390
- 15
FYI. Over the years, I've designed and built more than a few boats. Mostly commercial workboats and a variety of recreational fishing boats. I've also done a bunch of recore, re-stringer re-transoming and redecking jobs.
Back when dinosaurs roamed the earth, I started with polyester resin because that's what everybody used. Got the chance to use epoxy 20 years ago for a top-shelf customer and the difference between polyester and epoxy resins is night and day.
Epoxy:
- is more tolerant of temperature variations
- has much more adjustable cure times to aid in coring and laminating without rushing
- has a longer shelf life
- has less critical mixing ratios
- is significantly and provably stronger
- and most importantly, is for all intents and purposes waterproof, something polyester is clearly not.
Used to be that epoxy resin was prohibitively expensive. Name brand stuff still is. However, there are some reliable distributors that now have epoxy resin at quite reasonable prices.
The best distributor I've worked with is RAKA in Fl. They have a line of laminating resins and hardeners that are affordable and adjustable. They have three different viscosity resins and three different speed hardeners. And you can mix and match to get just the product you need. They mix 2 to 1. The current price for 6 catalized gallons - 4 gal. resin and 2 gal. hardener - is about $310 with $25 shipping. Can't beat that. I've been using their products for about 5 years and have been very satisfied. Plus they are a small company so it's easy to get someone on the phone if/when you need to.
Recoring and re-transoming is a nasty job. Just a suggestion, but if I were you, I would seriously consider upgrading to a full epoxy job. Price isn't that bad and the results will be superior.
Just my $0.02
Steve2ManyBoats.
12-13-2015, 08:25 AM #64
Wow, you know your resins. Thank you for the info. Soon after I ordered all my polyresin I started hearing more and more about the epoxy. I also hear one of the added bonuses to doing it in a garage as it does not stink the place up as bad. With the price I spent it's too late for me to switch over now but in the future I will definitely consider it. Thanks again for the info, that's why screamandfly is the best.
12-27-2015, 10:59 PM #65
1987 V-King YT 200 Evinrude Vindicator
1998 16' Weers HPT Pontoon 60 Evinrude 36 MPH
12-28-2015, 12:08 AM #66
12-28-2015, 12:26 AM #67
12-28-2015, 09:04 PM #68
Thanks Brian for the picture's, that will give me more of a idea of what you did for reinforcement's. I got the rest of center ground up today and ready for the core. I am planning on getting all the core in center to keep everything strait before I tackle the sponsons.
Bob
12-28-2015, 10:03 PM #69
No foam. Just recore the sponsons and leave them open while adding drain plugs.
12-29-2015, 12:37 PM #70
12-29-2015, 05:09 PM #715000 RPM
- Sep 2011
- Long Island, NY
- 362
- 78
- 13
Add a hole where that bulkhead meets the hull, you don't want water getting in an not able to drain. I just picked up an 86 Valero YT so I'm subscribed. I've done a core job before but this is my first tunnel type hull. Keep at it!
1976 Hydrostream Viper - 1500 Mercury I6
1985 21' Hustler - 2.4 200 Merc
1990 18' ArrowGlass CC 140 Johnson -SOLD
1987 21' Seebold Eagle 150 Merc
1990 15' Hydrostream Viper 150 Merc - SOLD
1977 16' Checkmate Trimate II 140 Johnson - SOLD
1969 13' Boston Whaler 40hp Merc - SOLD
Drive it like you stole it!
12-30-2015, 08:40 PM #72
Thanks Guy's for the input, as soon as I get the center core in, I will tackle the sponsons. I just can't wait!!
Bob
01-04-2016, 05:48 PM #73
01-06-2016, 08:21 PM #74
hydrostreamvking4m, D.ONEAL liked this post
01-06-2016, 11:43 PM #75
Bob, your hull is looking great, cleaned up much better than mine did. Hopefully the sponsons will be the same for you, keep the pics coming.
v king floor,core,transom
By roycesrolls in forum Fiberglass and Composites DiscussionReplies: 18Last Post: 09-17-2010, 07:50 AM -
V-king floor/core repair near orlando
By 200VEGAS in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 03-15-2010, 09:40 AM -
Mystery to me
By SDuster11 in forum Technical DiscussionReplies: 7Last Post: 09-15-2005, 10:42 PM -
Yet another mystery 260..
By RED ALERT in forum Technical DiscussionReplies: 21Last Post: 08-26-2003, 09:21 AM
