Page 1 of 11 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 1 to 15 of 164
    Jul 2009
    Worcester ma
    V-king YT re core mystery
ID:	325621Click image for larger version.
ID:	325622Click image for larger version.
ID:	325623Click image for larger version.
ID:	325624Has anyone even seen anything like this? i started to do the core in my YT the other day, the core on the sides of the pad came up no problem and was the normal rotted end grain balsa. But when i began trying to remove the core in the pad, i noticed extremely thick glass on top of plywood cut into strips on top of another 1/2 of glass..... no balsa in the pad (unless its under the plywood) which at this point wouldn't surprise me. i don't know why someone would ever do this haha... any ideas? the core in this thing must weigh 50lb with all that glass and plywood planking. its going to be hell to remove.
    Jul 2009
    Worcester ma
    So i guess what im asking is... Has anyone heard of a plywood Core?
    After a 30pk of Bud Light anything could have been put in..
    Nice talk with you Erik keep the thread updated as ya move along with the rebuild..Again call any time..
  4. Likes BeefKid liked this post
    Jul 2009
    Worcester ma
    Haha... i think it was a 30pk of Busch. thanks again for the talk the other day Brian, ill do my best to chip this junk out and start fresh.
  6. Likes hydrostreamvking4m liked this post
    Erik, has this boat ever had hull work on it before? I know a number of YTs went back to Hydrostream in the early days of that design for warranty work. Not saying that's related to this, but it's possible the hull has been worked on before - and - Hydrostream's build quality and methods have varied somewhat, quite often too.
    I would definitely like to see photos as you progress with it! I had a Valero YT and I always loved that hull design, except that it could spray you in the face sometimes at lower speed in chop!
    Jul 2009
    Worcester ma
    Hi Greg, thanks for the response , i know this boat was upside down at one point and the hull was blueprinted and coated in graphite. although it was a surprise to me finding this pad set up..... i will say it is unbelievably solid. i wonder if this could have been one of those returned YT's your talking about. I don't think this core was ever touched since Hydrostream. That's the best pic I could get at the moment...( ignore my hacked up trailer bunks) Valero YT's are awesome looking boats as well. we need to keep these boats alive
    Galveston County,TEXAS
    my 1970 13' Allison had plywood srips in the pad. From the transom fwd about 3 feet. The rest of the bottom was balsa core and all of it was original from the factory.
    its all balsa now
    limited skills
    Jul 2009
    Worcester ma
    Loop, that is exactly the way this is set up.... 3 feet of plywood and the rest is balsa. thanks for letting me know. I've never seen this before
    Jul 2009
    Worcester ma
    okay guys, i know i sound crazy......but. This plywood planking was actually done very well, and is surprisingly dry as a bone. i spent about an hour removing only 2 inches of it. i am wondering if i shouldn't just leave this pad section alone. i thought for sure that removing it was best, but now that i am tearing into it.... its is so solid, i feel i shouldn't mess with a good thing. i will use balsa up the sides of the pad and in the bow for sure though. Any thoughts? you guys have been very helpful.
ID:	325662Click image for larger version.
ID:	325663Click image for larger version.
    That is very strange. I've never seen anything like that before. I would hesitate to think Hydrostream did that.
    Sep 2008
    Treasure Island Fl
    I would leave it. You might mess up the pad trying to remove it. I'm sure it strong as hell. 3ft can't be too heavy. My old friend who has redone many cored boats, always did them lake this in the pad.
    Cawley
  14. #12
    Jul 2009
    Worcester ma
    Thanks guys, that's what i needed to hear. i'm afraid of punching through the hull trying to remove it.. it was done very well, i'm thinking it could have something to do with the pad being blueprinted in the past. The more of the old balsa i remove the more i see how nice this job was done. (the glass was only thick in front of the planking under the balsa) this pad must be bullet proof, and it is not nearly as heavy as i thought it was at first.
  15. #13
    Erik,
    I had to dig way back for the pic but found a shot of my yt pad and the repair they did to it..
    As you can see the core failed and while i think whom ever fixed it had no way of getting balsa core they went the way of building up many layers of glass..This I could have left and worked around it with new core but said nope no way im in here and its time to do it right..Well something like 20hrs latter it was out and gone..The probs with the pads in the yts is they will crack open the sides once the core is wetted out..So once I was back to the out hull I was able the lay out a new sheet of glass to build the pad strength back up before bedding in new balsa core from Merton Glass..Here's my pic...
  16. #14
    Jul 2009
    Worcester ma
    Wow, that's a lot of Glass Brian... I feel your pain with all the sanding and grinding. you really did a unbelievable job on that boat. if my pad wasn't completely dry, with no sign of ever being wet, I would never even think of leaving it in..... I have some real thinking to do.
    do you have any pics of your gutted out sponsons?
  17. #15
    Dec 2004
    Easthampton, MA
    YT Sponsons
    http://www.screamandfly.com/showthread.php?251132-YT-sponson-core-replacement
    hope this posts correctly. What I did with mine.
  18. Thanks masonadaddoo thanked for this post
  1. v king floor,core,transom
    By roycesrolls in forum Fiberglass and Composites Discussion
    Last Post: 09-17-2010, 07:50 AM
  2. V-king floor/core repair near orlando
    By 200VEGAS in forum Fiberglass and Composites Discussion
    Last Post: 03-15-2010, 09:40 AM
  3. Mystery to me
    By SDuster11 in forum Technical Discussion
    Last Post: 09-15-2005, 10:42 PM
  4. Yet another mystery 260..
    By RED ALERT in forum Technical Discussion
    Last Post: 08-26-2003, 09:21 AM
