Results 1 to 3 of 3
    wisconsin
    04 250 xs opti Low low hrs
    boat delaminated so time to cut my losses and start over.
    2004 250 xs optimax
    25 inch shaft, HD transom bracket
    less that 30 hrs on it since complete rebuild
    new head and rod bolts
    new direct injectors, fuel injectors were flowed and cleaned
    new spark plugs
    new gaskets
    new compresser belt, newer compresser
    new fuel pump
    new rod bearings and wrist pin bearings
    6 new wiesco pistons
    bored .o15 over size
    fleet master gear case with 1.75 gears and new seals
    water pump was replaced too
    It runs perfect 0 issues
    hood has a hole busted into it in the top corner, dont affect any thing but looks, and the decals are kind of flaky
    $7500
    Attached Thumbnails Attached Thumbnails 10250047_542159114639_3883161073548931182_n.jpg   11866268_550498597249_6570028569119907979_n.jpg
    Aug 2005
    port orchard , wa
    Nice motor,who did the rebuild?
    wisconsin
    I did, certified merc tech. Not a backyard hack job
  1. Regular 225 Opti vs 250 Opti XS
    By stingray240cs in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-06-2018, 03:28 PM
  2. Dual Repower 225 opti, 225xs or 250xs/opti
    By fishnchips in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-18-2008, 08:18 PM
  3. Pro Max, Opti Max....ect??
    By Tony P in forum Technical Discussion
    Last Post: 09-10-2005, 05:48 AM
