Results 1 to 3 of 3
    Mar 2004
    Brooklyn Park, MN
    White gel stained from water at race
    finally need to clean the viper, white gel and it has a black stain from some oily waters at three lakes. I got most the heavy off but need to either polish the rest off or something. Would On Off hull cleaner be the choice or are there less aggressive products out there. I used dish soap to get most if it off but even gas does not get the stain completely off. Never had to use anything aggressive on previous boats, but none were white and used the other boats in cleaner waters all the time where cleaning was not really needed. Most the mess usually is from the road!
    thanks
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Dec 2004
    Frankfort KY
    Try Works tub and shower. I used it on mine and the hull was yellow from water stain now bottom shines like the top and mine is white as well.
    1998 SS 2000 94 260ss
    Speed cost how fast you want to go
    Allison and Merc is there anything else?
    Dec 2011
    Ludington michigan,on the shore
    Go to aircraft spruce website,look for a product called carbon X use as directed it will come clean.Used to remove Exhaust or any carbon based stain from aircraft,used it for years.Im sure it will remove carbon based stains from gel coat.
  1. White Haven PA Walter Dam race
    By Mark75H in forum General Boating Discussion
    Last Post: 06-16-2008, 01:18 PM
  2. White Water River Racing!
    By tphoto in forum Racer's Hangout
    Last Post: 11-10-2006, 07:18 AM
