Results 1 to 4 of 4
07-15-2015, 11:26 AM #1
Honduh stuck in version of limp mode at 4000 RPM
BF90 Jet... UGH enemic at best but I digress tach is accurate, blades of carbs are fully open, all cyl firing but engine hitting limiter at 4000 rpm, only literature i see shows only Low oil pressure or high temps will cause issue similar, but got good oil pressure and can bypass sensor and get oil pressure light to come on as if there is good pressure, same with water temp bypassed sender still seeing limp mode limit of 4000 RPM
any Ideas where to look,
CDI? Cam timing?
Crank Sensor
Cam Sensor?
Timing??
Harness??
Controll Box and alarm system??
will not even free rev beyond 4200Last edited by 150aintenuff; 07-15-2015 at 11:30 AM.
07-15-2015, 04:43 PM #25000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
Don't know much about Hondas, but 4000 is high for a limp mode, I suspect you have other trouble.
Free revving is awful hard on motor.
pointer
07-15-2015, 05:25 PM #3
mn808gade liked this post
07-24-2015, 11:59 PM #4
FOUND MY ISSUE... Sheered crank key and Jumped Timing by about 4 teeth... how it even still ran is beyond me without hitting valves after a little tweek and cut on the Jet impeller seeing 5800 RPM im happy again
2003 merc 200 efi limp mode after electronic oil inj removed
By travisl in forum Technical DiscussionReplies: 10Last Post: 06-16-2015, 09:22 PM -
1997 Evinrude 150 Ficht Intruder - warning horn/limp mode
By thill in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 12Last Post: 05-28-2015, 11:36 AM -
200 efi slow mode
By outrace in forum Technical DiscussionReplies: 3Last Post: 02-17-2006, 02:36 PM -
280 Break In Mode?
By RED ALERT in forum Technical DiscussionReplies: 13Last Post: 10-22-2005, 08:04 AM
