Results 1 to 9 of 9
Thread: Mercury 200 motor
07-15-2015, 09:07 AM #1Junior Member
- May 2013
- Houston
Mercury 200 motor
Ok i think i need some help identifying this motor to start with. serial number 5321329.
History 2 years ago: I bought a boat from a guy that did not have a motor on it. He tells me he has a Mercury 200 racing motor that he was going to put on the boat. I have an old 150 so i didn't buy the motor. He told me the 200 had been set up as a race motor with some type of good lower unit ect. The entire motor, cowling and all has fresh paint- like factory, not rattle can.
Anyway, the guy passed from a heart attack and his widow asked me if i would take the motor for free and i did. came with power trim controls, everything.
Just got it home and hung it and that's about it. I will get around to mounting it on the back of a boat i have so i can do some tests , compression, rewire so things ect.
Can anyone tell me about the chrome lower unit? are these good motors? what should i look for in particular?
phase3looper thanked for this post
07-15-2015, 09:48 AM #2Junior Member
- May 2013
- Houston
07-15-2015, 10:19 AM #3
Not a race motor stock 2.4 or 2.0 135-200 hard to tell by the pics lower is nothing special either good old motors with a little care
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
99 action craft flats boat
88 xr2002
90 Stv pro comp
10 mirage 1/4 master
98 mirage 1/4master
Raceman liked this post
07-15-2015, 10:43 AM #4
Not a 200 either.... vertical reeds
07-15-2015, 11:01 AM #5Junior Member
- May 2013
- Houston
thanks guys, i did pull the plugs and it looks like bottom left (6) piston has moisture in it.... been stored about 8 years so not sure how that happened.. guess ill pull the head... Got the title now, it shows it as a 1979 200..
Anyway, if the number 6 has an issue then ill just part it all out.
07-15-2015, 11:10 AM #6
Hmmm. Does the serial number on the title mach the serial number on the freeze plug on top of the block? What is it?
07-15-2015, 12:46 PM #7Junior Member
- May 2013
- Houston
ahh very good question, not sure on the freeze plug. Title and the serial on the bracket match - 5321329. But the top could be totally different. Ill check that out this afternoon. I actually was given two boxes of stuff with it and there is a total setup from reeds to carbs all bolted together in the box along with other parts- extra carbs, fly wheel ect. . Guess you would say extra parts lol.
So ill check the freeze plug number but it looks like it may have had some stuff swapped around or meant to be swapped around at some point.
07-15-2015, 02:30 PM #8The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
It very well could be a 200. A vertical reed 200. In the late 70's & early 80's, this was Mercury's 200. At the same time, they also produced the 225, the first horizontal reed V-6, beginning in 1980. In 1984, Mercury began propshaft rating the larger horsepower engines. The 1983 225 then became the 200. The 200 became the 175. The 175 became the 150. All of Mercurys V-6 engines, since their first introduction in 1976, were vertical reed engines, until the first 225 became available. If you have, what we think is one of these late seventys chrome-bore, powerhead horsepower rated 200's...and the chrome cylinder walls are still good, you have what was in those days, a very good performing engine. I would recommend a compression test of all cylinders, and have an experienced outboard mechanic rebuild the carburetors, BEFORE you run the engine. Carburetors on these engines that don't flow properly, that have been sitting in disuse, WILL lean out & ruin an otherwise clean chrome bore cylinder. Its does'nt cost a fortune to do. Then, only feed this engine good, clean quality fuel & 50:1 water-cooled 2-cycle oil.
07-16-2015, 06:21 AM #9
Just a reminder, the clamp bolt patterns is not BIA like the motors from the 80's to current. I think the top two holes a narrower than the standard BIA pattern.
1973 Viper - sold
1978 Viking - sold
1995 XB02
Mercury motor
By SAMMY CORLEY in forum General Boating DiscussionReplies: 1Last Post: 06-15-2014, 04:24 PM
