Results 91 to 105 of 120
Thread: Solas Scorpion prop test
05-17-2017, 04:30 PM #91
yes if you buy the one that uses their RubX hub it the same as a flo torque. THe prop also comes in solid hub
whipper liked this post
05-25-2017, 12:00 PM #92
So Scorpion or Rubex L4 that has vent holes already? What is the max Diameter prop for a TM small shaft any one know?
http://www.solas.com/newweb/propelle...arch_rubex.asp
05-25-2017, 01:00 PM #935000 RPM
- Jul 2004
- ontario
- 182
- 18
- 59
- 24
05-25-2017, 01:09 PM #94
05-25-2017, 01:14 PM #95
I just drilled them to 3/8" and see if my X will get it out of the hole ok. Can always drill them bigger, now if the rain would stop
06-03-2017, 03:37 PM #961990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
vnemous thanked for this post
06-04-2017, 11:35 AM #97
06-04-2017, 12:52 PM #98
no I just drilled the pilots out to 3/8. If that doesnt work I will go to 1/2" but Doc says it should be ok and he would know. Hole shot may no be ideal but Im sure it will get on plane
06-09-2017, 06:02 PM #99
So I thru the boat in the water an hour ago just to see if she would get on plane. She did but it was tough, gonna need much bigger vent holes. For those that dont know my x has just a tuner and no exhaust can down to the prop so I dont get much ventilation. Once on plane it ran very well. 87 mph at 5800 rpms works out to 4-6% slip figuring the 27p is reallly a 29-29.5p. I had plenty of pedal as my redline is 7000 but I didnt have my vest on and this was just kinda a shake down to see if it would get out of the hole. More to follow.
06-09-2017, 11:57 PM #100
So when you say trouble getting on plane you mean spins up higher rpm but doesn't bite? Also wondering if maybe I should try a 25 instead of the 26 if they run that tall? I can spin well over 7000 but like to prop to 7200max. Want hole shot and mid range more than top end. I have a drill press and access to a Machinist at work for the 3/8 holes maybe 1/2 inch buy the sounds of it?
06-10-2017, 12:34 AM #101
06-10-2017, 12:36 AM #102
Im really liking the look of this Solas Pro L4 with vent holes. New design but looks like a Promax or brovo cross. Any testing with anyone on this bad boy?
06-10-2017, 02:43 AM #103
One more thing why not 1 inch vent holes like the Bravo 1 ? Even dual ? Ive seen 1.25 holes with some mods and they seem to perform.
06-10-2017, 04:10 AM #104
No the prop does not vent so it does not spin up. My trophy has stock vent holes with no plugs plus an additional 1/2 in holes and vents fine. Of course the pro et does not have this problem since its not a thru hub.
06-10-2017, 09:42 AM #105
What's Solas web site link?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
Solas Scorpion
By Walleyehed in forum Props, Setup, and RiggingReplies: 17Last Post: 05-27-2016, 02:53 PM -
TXP versus Tempest Plus (also, Yamaha T1/Solas Scorpion)
By engineermike in forum Props, Setup, and RiggingReplies: 25Last Post: 10-16-2011, 04:25 PM
