Results 61 to 75 of 120
Thread: Solas Scorpion prop test
03-21-2016, 05:08 PM #61
go 2-3" lower than a comparable Merc prop.... a 18 L4 has exact same blades as a 22 Bravo... and a 23 Scorpion is more agressive than a 25 tempest
BEST PROP OUT THERE FOR THE BUCK!!!
03-21-2016, 05:12 PM #62
each blade carves a new path if you spin it and look at it from the side this is done as im told by their design rep so the following blade enters non aerated water behind the blade in front of it so if you spin them they look off ballance with relation to the blade tips
i sell probably 10 or more Scorpions a year and countless Lexor models and each one will semi surface and fully surface from the box... only in extreme bow heavy fishing boats does the tip cup need to be added to and thats only in none or very short setback lengths
above 22P you almost always need 2 5/8" vent holes behind every blade even thru prop exhaust sterndrive ive sold needed a bit of venting to get the motor spooled upLast edited by 150aintenuff; 03-21-2016 at 05:16 PM.
05-01-2016, 03:33 PM #63
Solas scorpion prop test
Great info, I almost bought one yesterday that would not have worked based on that. Thanks[/QUOTE]
PUT my 150 on stand and bolted up a 2,4 mariner magnum same prop but 1 87 lower 75 gps @ 6000 works out to 0 slip with 24p have to concede scorpions are measured differently if i calc for 26 pitch i get about 8% slip, a believeable figure boat is only 15,6 and 700 lbs i didnt want a coned lower but it came with it, the 3 piston trim wieghs a ton 150 had single piston and now inboard oil tank another 20 lbs. i think 80 is possible i have a 26 chopper to compare to the scorpion. do you think i really need a cone to run high 70s? ART
05-01-2016, 03:38 PM #64Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Terri, do you want to sell or trade the Scorpion to me?
05-01-2016, 07:57 PM #65
IF i can find something faster ill do that! i really need a 26 scorpion my merc mech oil pump gear running 6000 is pushin it. what props do you have? they make them in 1p increments a 25 would be perfect for me.
05-03-2016, 06:37 PM #66
Used scorpion prop found
RE find on louisanna sportsman.com its a 27p looks like new! too big for me CHEAP DONT for get its really a 29p
05-04-2016, 06:09 AM #67Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Terri, what pitch is your Scorpion?
05-07-2016, 09:31 AM #68
i got a 28 if anybody needs one thats had 1 demo run on it and about 3 years of shelf dust on it 9/10 it ran equal to a 30 Bravo, RPM wise, and 4 mph faster than it...
05-08-2016, 01:41 PM #69
M24 SCORP runs @6000 w\ 1.87 lower 75 gps. super happy!
05-08-2016, 01:44 PM #70
24 terri
05-08-2016, 02:45 PM #71
[QUOTE=150aintenuff;2855448]i got a 28 if anybody needs one thats had 1 demo run on it and about 3 years of shelf dust on it 9/10 it ran equal to a 30 Bravo, RPM wise, and 4 mph faster than it...[/QUOTEIs
Is the 28 a flo torq ?
If so please PM me...thanks1990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
05-09-2016, 04:20 PM #72
my scorp 24 @6000 runs 75. leaving everything same going to test against my 26 bigear chopper. very curious let ya know real soon ART TEST complete barely get hooked with chopper steering torque huge my arms are acheing porpoise starting at 55 had to drive through it. but on the up side turned 6000 also @ 75 gps same lake
05-10-2016, 12:54 PM #73
What are you wanting for the 28? I've been wanting to try one. Sean
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
05-25-2016, 06:53 AM #74
Hunt around online you can find them new for below 400.00 and many new ones have flo torque hub set up which is more adaptable.
They are also listed as Solas S3 propeller.
They also must be run above the pad and the higher the better for best performance. If you find you have too much bow lift ( feels like the nose is searching ) then means you should reduce motor setback. Only prop I have found that could give you too much bow lift.Last edited by dnelson964; 05-25-2016 at 06:59 AM.
05-25-2016, 08:50 AM #75
Yes, I may have to try one. Sounds like a decent prop.
2008 Mercury 300XS
91.7 - MPH
102 - MPH
Solas Scorpion
By Walleyehed in forum Props, Setup, and RiggingReplies: 17Last Post: 05-27-2016, 02:53 PM -
TXP versus Tempest Plus (also, Yamaha T1/Solas Scorpion)
By engineermike in forum Props, Setup, and RiggingReplies: 25Last Post: 10-16-2011, 04:25 PM
