Results 76 to 90 of 104
Thread: redesigning a pad
09-18-2015, 07:41 AM #76Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Looking real good....Makes me itch just from the pics..
09-18-2015, 07:47 AM #77Member
- Feb 2013
- Wetumpka, Al
- 52
- 12
- 12
09-18-2015, 08:44 AM #78Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Talcum powder before the grinding, cold shower after it. This was my schedule when I had a glass shop for 20 yrs. It helps some. Good fan to blow the dust downstream is good too. Over the years I got sensitized to all the chemicals and glass dust. Had to give it up to keep healthy. Liked the work tho...
allouttrimmed thanked for this postSlimm liked this post
09-20-2015, 02:06 PM #79
09-20-2015, 02:15 PM #80
I have not complained when working outside on a breezy day. Suit on and airhose in hand, blast the dust piles as they form and the wind just takes it away. This just left less of the dust to permeate my suit. I am sure the critters in the woods may not have been happy.
Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
09-20-2015, 05:00 PM #81"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
09-20-2015, 06:04 PM #82
olboatman liked this post
09-20-2015, 07:16 PM #83"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
09-20-2015, 08:44 PM #84
Looking good! subscribed...
Cawley
09-22-2015, 09:22 AM #85Member
- Feb 2013
- Wetumpka, Al
- 52
- 12
- 12
Things are going a little better now. so i have a question on after finishing ny sanding then priming. using durateck primer is what i believe you guys have said would be best, what else with the primer needs to be added or just clean and shoot the primer striaght? Thank again for all your help. Buddy
09-22-2015, 09:32 AM #86Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Might use a lil thickened gell to fill any deep scratches and bigger pin holes. Just spot sand this filler some. Apply a heavy coat of primer and go around looking for pin holes. If some are found take some primer and fill them using a broom straw or something like that. Then shoot the remaining coats to get the build up you need. I hate filling pin moles after doing the primer.. I use the primer mix right as it comes out of the can. Use a 2.0 gun tip or bigger.
09-22-2015, 09:38 AM #87Member
- Feb 2013
- Wetumpka, Al
- 52
- 12
- 12
Vking I cna't thanl you enough for all the help you have been with helping me on this thread. I really appriciate your posts.
10-14-2015, 07:41 AM #88Member
- Feb 2013
- Wetumpka, Al
- 52
- 12
- 12
Well I can say after several months of bad days and more sanding than I can have imagined this job is very close to being completed. I have a gallon of duratech primer and mek catalyst, I ordered a gallon of black gel from Stratos to match the color already on the bottom as not all of it is having to br sprayed, the question I have will be what additives do I need to add to gel such as styrne and wax, I am going to call Startos back this morning to find out what gel they use if they will tell me and go from there. Thanks for any help.
12-14-2015, 10:36 AM #89Member
- Feb 2013
- Wetumpka, Al
- 52
- 12
- 12
12-14-2015, 10:43 AM #90Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Looks good even upside down...
