Results 1 to 4 of 4
    longisland ny lindenhurst
    2.5 carb difference?
    Early 90s 2.5 200 merc. The carbs that are on my engine have the pumpers on them. In the beginning of the year and yesterday i almost lost my engine due to those pumps. I had the clips pop off which caused the plunger and spring to pop out. Every tome they pop out theres a chance of sucking them down the carbs and killing the engine. I have another set of carbs without the pumps that im looking to switch too. Is there any differnce between the t to?
    Thanks edd
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    Jul 2002
    FT WORTH, TEXAS
    there some numbers stamped on the throttle linkage side of the carbs, they are probaly jetted different , i personally hate them pumpers and gave 4 sets to james perry , the next geeration of those lil gems had the pump casting but no pump then they finally stopped with the casting they are wmh carbs what horse power are you running
    Jul 2002
    FT WORTH, TEXAS
    it looks like wmh 3 which are orginally from a 200 hp if you can find some wmh21 they are good carbs for a 200
    Hp is prob around 215-220 spins around 68- 7k. The pumpers are the orignal carbs to this engine just with fat jets. Im thinking on taking the bowls from the other set of carbs and swap them out with mine.
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  1. 1976 I6 115 How to tell difference between KD and WMK carb
    By coffeeguy in forum Technical Discussion
    Last Post: 06-07-2015, 09:38 PM
  2. Mercury Tech: difference between wh-22 carb & wh-28 carb...
    By buzmacdowell in forum Technical Discussion
    Last Post: 06-30-2014, 10:39 AM
  3. Difference in the 2002 -2005 2.5L Carb and EFI Blocks
    By Go Time in forum Technical Discussion
    Last Post: 12-06-2013, 12:25 PM
  4. Difference between 2.4 BP carb and EFI blocks?
    By STV_Keith in forum Technical Discussion
    Last Post: 09-03-2002, 06:27 PM
  5. difference between 2.4 xri efi and 2.5 l carb motor ??
    By MennoNetherlands in forum Technical Discussion
    Last Post: 10-18-2001, 06:42 PM
