Results 1 to 2 of 2
Thread: Bigfoot 40hp EFI fuel pressure
06-28-2015, 05:46 PM #1
My dad has a fourstroke Bigfoot outboard with EFI on his pontoon. It has a high pressure line from the high pressure fuel pump to the injector distribution. The end of the line are black plastic, with a red plastic clip of some sort. Do I push or pry on the red piece to get it separated?
Thanks.
Also is there an adapter available to mate my Ford fuel pressure test guage to the smaller mercury sized test port?
08-23-2015, 10:36 PM #25000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
just push in.lots of probs with black rubber pieces inside rear mounted fuel pump and VST.melts from ethanol-th
Do I need to run a fuel pressure regulator with a Holley Red fuel pump?
By Steve2ManyBoats in forum Technical DiscussionReplies: 14Last Post: 03-31-2011, 08:09 AM -
OMC Tech: OMC LOOPER FUEL PRESSURE:output on fuel pump / vapor separator is not steady (< 3PSI)
By foca1 in forum Technical DiscussionReplies: 5Last Post: 06-01-2010, 06:48 PM -
Recommended inline fuel filter and fuel pressure regulator
By topkick in forum Technical DiscussionReplies: 2Last Post: 09-20-2005, 09:25 AM
