Results 1 to 8 of 8
Thread: What mid/lower unit is this?
06-23-2015, 03:15 PM #1
I'm looking into a new project of a 2005 Seebold F1/F2 composite tunnel (will post more if this project gets underway) and have searched up a 12" mid section and what I believe is a #6 SSM case for this boat.
It looks quite old and I have not seen this "cut" of the exhaust outlet before and can anyone tell me what this is (also the case as I'm not sure...)?
Thanks!
06-23-2015, 03:55 PM #2
Looks like an old style 12" mid with a #6
06-23-2015, 05:27 PM #35000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
x2 Make sure all the bushings are tight. Less slop the better.
06-23-2015, 06:07 PM #4
I have read that the SSM's are quite expensive to rebuild...?
Where should I send it for a check/rebuild (if needed) and what company is best for parts supply?
Anyone that can tell me more about the 12" mid and exhaust plate?
As mentioned it looks old and I think the exhaust outlet looks strange but approx what year can it be and does it look original?
Any idea what price I should pay for this "setup" (have not finalized negotiations yet)...
Thanks,
LarsLars P Helminsen
Hvaler Islands, Norway
Birchwood 29 / Evinrude 225 - Pleasure project
Moore F2 / Merc 200XS SST - UIM F2
Seebold F2 / Merc SST120 - UIM F2 - Sold
Lustcat 18 cat / Merc XR2 - Sold
Hydrolift CR24 cat / Merc XR2 - UIM Offshore Class 3C 2L - Sold
Argo 22 cat / Merc XR2 - UIM Offshore Class 3C 2L - Sold
Argo 21 cat / Merc XR2 - UIM Offshore Class 3C 2L - Sold
Hurrycane 470 v-bottom / Merc 115 In-line 6 - Sold
Hurrycane 370 v-bottom / Yamaha 30 - Sold
06-23-2015, 06:59 PM #55000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Could be as old as late 70's, looks original. It is what is known as "studs down" later models are studs up. Gearcase cost really depends if it needs gears or not. http://www.colabellaperformance.com/ is a respected place for the gearcase.
06-28-2015, 11:34 AM #6
Thanks again Dave!
Here is another pic of the case. I don't know this but does these numbers say anything about it?
Also the only numbers I can find on the mid...
This "setup" also comes with an exhaust tuning plate (don't know the right word for it) and can anyone see anthing from this? What motor it is for etc.?
06-28-2015, 11:41 AM #7
Attachment 322498Attachment 322499
The "offshore style" exhaust outlet on this mid, is it normal to cut/modify this to get the exhaust blow straight backwards and not down?
Thanks,
06-28-2015, 11:46 AM #85000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Some do, some don't. If you ever want to sell it that may affect value to a collector or restorer.
mercury quicksilver lower unit vs tourqmaster lower unit
By jshotts in forum General Boating DiscussionReplies: 3Last Post: 01-26-2015, 01:23 PM -
Mercury Tech: 2.4, 2.5 liter fishing lower unit into a 3.0 torque master lower unit
By cactusth in forum Technical DiscussionReplies: 3Last Post: 08-12-2011, 09:51 PM
