Results 1 to 12 of 12
    Nov 2012
    United States Oak Creek, Wi.
    overheating issue? Poppet valve?
    The guy removed serial numbers and its a 2.4 200 hp block, lets say 1986? it runs through long slow no wakes perfect, once on plain, it rises to over 215 degrees, i shut down and idle and goes back ok. Fresh engine, and water pump last year, strong 6 foot stream, poppet valve? i have been told? how expensive and are parts readily available to do myself? what is time to install? thanks, JIM
    Previous Boats:
    77' Switzer Craft 72 mph 175 hp
    86' Lazer LTV 80 mph 200 hp
    90' HST Bridgeport 97 mph 250 hp
    86' Valero YT 80+ mph 200 hp
    79' Vector 80+ mph 200 hp 85' Valero V 83+ mph/ Current 200
    88 Valero YT not so fast, no good motor
    NOW 85' Valero Vee 2.4 Bridgeport Carbs
    Feb 2003
    Rochester, NY
    Where are your water intakes in relation to the transom? The reason I ask is that if your motor is mounted (or raised on a Jack Plate) too far, you can easily have great water pressure & cooling at idle and lose it once on plane. What's the "strong 6 foot stream" look like once on plane?
    1992 Progression 22
    Mercury Racing 250R
    Nov 2012
    well i do have a jack but was running motor all the way down on jack testing boat for some tubing we are planning with guests. i have water temp, pressure and tach, i use a lot. I think we have a poppet issue, since motor is really low on transom when down and although no cone on this one, i am only driving around at 30 mph hardly on plane, so motor is deep.
    Previous Boats:
    What is the pressure and rpm at 30 mph?
    If your running a high pitched prop and skiing, tubing etc. That can make it run hot, if thats the case try a prop with less pitch.
    Nov 2012
    we pulled the spring out of Poppet valve and all is fantastic now, running nice low temps! Thanks guys!
    Previous Boats:
    Jul 2004
    ontario
    Quote Originally Posted by Valero2.5 View Post
    Well that's kinda weird because it shouldn't. The poppet valve is there to release excess water psi, if you pull the spring it shouldn't have much psi if any at idle, might be okay once your moving.
    Poppet should open just over 10 psi. With no spring would at less press. Have something strange going on.
    Nov 2012
    good stream at idle and nice low temp now so we are happy til parts come in for new poppett, on to the other motor with trim issue, this case closed. Thanks, JIM
    Previous Boats:
    It works just fine, leave the guy alone...
  11. Likes perfmarine1, Dave Strong liked this post
  12. #11
    Oct 2010
    Harrisburg,Pa
    LMAO.
  1. Mercury Tech: Poppet Valve kit - which one for this poppet?
    By gmacrae in forum Technical Discussion
    Last Post: 10-07-2014, 04:53 PM
  2. Poppet valve/relief valve issues 1978 2.4l Merc
    By rujr in forum Technical Discussion
    Last Post: 06-24-2013, 08:21 PM
  3. Mercury Tech: poppet valve?
    By TahitiDave in forum Technical Discussion
    Last Post: 01-10-2012, 10:24 AM
  4. Poppet Valve
    By RICHARD TATE in forum Technical Discussion
    Last Post: 08-06-2007, 04:29 PM
  5. Poppet Valve
    By bucket in forum Technical Discussion
    Last Post: 09-21-2002, 07:34 AM
