Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Lithium Batties
    Richland, WA along the Columbia River
    Lithium Batties
    Well it was time to replace my Optima batteries.
    I don't know about you, but I seem to get four years out them. I store my boat indoors put them on a trickle charger a few times over the winter, but they seem to get weak.
    I decided to upgrade to LFP, Lithium batteries. These are 800 CCA with 1500 peak cranking amps.
    The beauty of it is they have an order of magnitude more cycles, which I hope translates to longer life. The LFP's only weigh 6 lbs each.
    I saved over 100 lbs replacing three Optima's with three Lithium batteries. I also saved probably 20-30 lbs of 2 gauge cable running from upfront under the dash to back in the bilge. I was using the Otpima's as counter weights since I have two 300xs hanging off the back. I mounted the Lithium Batteries back in the bilge.
    I was apprehensive about the real power of the Lithium's they were so light how could they produce that much power. I wired them and the cranked the motors and they fired right up.
    I am using one of the Lithium's for my stereo. I don't have a big stereo setup, just 800 watt amp, 1 - JBL sub, 2 - eight inch and 2 - 6 inch. I ran it for over an hour in my shop and tested the drop in voltage. I started with 12.8 volts and after an hour powering the stereo the voltage only dropped to 11.9 volts. Now I have to admit I wasn't cranking on the stereo, but I was still impressed.
    Time to clean up the bilge and get to the river. I will let you know what I think after a few days of run time.
    Attached Thumbnails Attached Thumbnails Lithiumax Battery.jpg   Daytona 22-10.jpg   DSC_6759.jpg   Bilge1.jpg
    Jun 2002
    Waterford, CT
    I have wanted to try these for years.
    My interstate rep scared me with the fear of fire.
    Interested how they work.
    Good luck
    SE MN
    Lithium Ion cannot be extinguished Lithium IRON (LFP) can .
    Feb 2007
    lily lake WI
    Look up tesla fire on YouTube scary
    shreveport,la
    12.8 sounds low for lithium. Check the manufacturers recommended charge. It more than lead/acid. Usually around 14.0. My lithium batteries would be dead as a hammer at 12.8. I charge them to 14.0-14.1. They quickly settle in at 13.3 and hold there
    Erik Kiser
    Patches you are right, when I pulled the trickle charger the voltage was above 14, but by the time I finished hooking the stereo up, I had used some of the charge. I was a little surprised to see the peak voltage above 13 volts, since the battery consists of 4 - 3.2 volt cells. In my book 4 x 3.2 is 12.8, but I am not an electrical engineer.
    I went with Lithium Ferrous Phosphate (LFP) because I had reservations about the Lithium ION fire and over charging hazard. If you do the math, the Lithium ION batteries have higher power density, but it is only fractional.
    When you compare the power density of LFP's with AGM Lead Acid batteries, the LFP's are in a whole another league.
    shreveport,la
    Lithium batteries are mind blowing. I can start my motor that has almost obscene compression 40 times on a battery that weighs 4.4 lbs. My old trim batteries weighed 15 oz each. It's crazy
    Erik Kiser
    8 Post(s)
    which brand are they, where to buy?
    USA
    Quote Originally Posted by jpf091959 View Post
    Can you share a link for these batteries? Thanks
    I shopped around and really wanted to buy American made batteries but ended up buying batteries made in England and sold out of Australia.The US Dollar is very strong right now, so you get a lot over sea's.
    I made them an offer and we negotiated a little back an forth. I wanted the battery box and shipping. I modified the battery boxes slightly. Shipping could not have been easier. it took 7 days from Australia to my door.
    The distributor and I communicated via text a few times and even though he was at the race track with his car, he took time to answer my questions.
    Here is a link.
    They now have a 850 amp, I would have purchased them, but wasn't available at the time. The 800 CCA are doig the job.
    http://www.lithiumax.com.au/support
    http://www.ebay.com/itm/231513264619...%3AMEBIDX%3AIT
    I also purchased some battery post 6mm thread and quick connectors. I like the setup and so far very pleased.
    USA
    Thanks for the info. I was looking at replacing my two batteries with 4 or 5 of these so please report back in a month or two as to how you like yours.
    http://sepbatteries.com/battery-tend...FUsXHwodw5AAdg
  12. #12
    Aug 2012
    Tenkiller Lake, OK
    Check out StarkPower Ultra Start SP-12V36-US5 $389 plus a free charger.
  13. #13
    Jul 2004
    houston,tx
    im very interested in how the batteries test on the stereo side on a day of usage
    lithium batteries have big cranking amps
    but have a shorted reserve/deep cycle than a agm battery
    as the lithium gets hot from a large load is when they have the reputation to burst
    I have been using lithiums on our drag motors for over 6 yrs at the strips on numerous builds
    and found crank amps great
    but with all the electronics draw from ignitions,vacuum pumps,fuel pumps,nitrous solenoids,and rest of electronics
    a pass load is around 80+ amps in the short period motors is loaded
    and the batteries were dropping to and below 11.8 volts
    and that's where an ecu shuts off
    so still use amg batteries on main power and lithium for starting only
    just as in ur 1 hr stereo test at low volume control fell to 11.9 amps
    its the heat the batteries make under a prolong load that makes voltage fall quick 1nce they get hot
    keep informed on how they do
    optima and oddessey batteries are still high on the battery line for boats
    all others from auto parts,walmart including interstate are all made by the same manufacturer just with different labels
    so now a days hoping to get 2+ yrs on a standard battery is common
    as plates are made thinner to get more amp power
    by having more contact to the alcalyne solition
    this shorting the life of the battery
  14. #14
    Aug 2012
    Tenkiller Lake, OK
    John, Won't the alternators continuously keep the batteries topped off when the motors are running?
  15. #15
    Jul 2004
    houston,tx
    I have never tried the lithiums in a boat,,,,
    as why courious on the draw from the stereo through the day
    the alternator charging creates heat also,,,,,
    just what I have found on my builds and others at drag strips is the deep cycle side
    of lithium does not last as long as a good deep cycle battery
    lots of the lithiums are stacked batteries to create the voltage
    and take a special charger that reads the individual cells
    so not to overcharge 1cell to get too hot and burst
    on an alternator its charge is prolong/hard/full ,,,thus more heat
    I went from stacked batteries to
    12v lithiums from shoria made to be a replacement for oem on cars/motorcycles
    to be used specifically on an alternator
    still the battery would not keep up on the voltage drop from the amp draw
    and through time the draw/heat kills a cell
    these batteries have made great progress from stacked single cells
    to these new oem replacements
    cost me lees to stay what works for me
    agm on deep cycle,,lithium for start
    I don't know all ,,,
    just what ive found in my R&D on builds for me/customers through the yrs
    on high load applications
