Results 1 to 15 of 22
05-13-2015, 03:32 PM #1
1983 Evinrude 35HP how to replace clutch dog?
I got a 1983 35HP Evinrude E35ECTS. I got the bearing carrier out and the snap ring and the big washer, but to my surprise the shifter thingy is blocking me from being able to pull the prop shaft and forward gear out. there is a little pin on the bottom of the shifter thingy that is going around the prop shaft. surely I am not going to have to get that little pin out down inside the casing?? I just want to replace the clutch dog. Is there and easy way to get to it??
05-13-2015, 05:12 PM #2
If I remember right, there is a screw in the side of the case right in front of the drain plug that needs to come out....it the pivot pin.....
05-13-2015, 05:23 PM #3
I will try to post a pic tomorrow. I saw that screw. but there is still the shifter thingy that is blocking the shaft from coming out.
I never worked on a gearcase smaller than a V-4
05-13-2015, 06:42 PM #4Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Once it's out check the shoulders of the gears at the contact surface with the clutch.
05-13-2015, 06:55 PM #5
You also have to remove the shift shaft....... the whole thing slides out without the gear
05-13-2015, 06:58 PM #6"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
05-13-2015, 09:25 PM #7
05-13-2015, 09:50 PM #8Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,097
- 1008
- 354
- 4297
- 1953
- 7 Post(s)
The pick does show the lower shaft, item 49 it screws into item 12, remove it.
Remove screw 36 and then I think it all slides out from memory?
what I do remember form 30 years ago was I didnt look forward to fixing one
They key to making them last was the adjustment up behind the lever on the powerheadLast edited by powerabout; 05-13-2015 at 10:02 PM.
05-13-2015, 10:02 PM #9
yea, that screw #36 is a pin with a tiny cotter pin holding it, and it is all down inside the gearcase in a very difficult spot to get to. I can see that this is not going to be a fun day.
05-13-2015, 10:06 PM #10Screaming And Flying!
- Jun 2007
- 9,097
- 1008
- 354
- 4297
- 1953
- 7 Post(s)
05-14-2015, 04:17 PM #11
so all i need to do is remove the shift rod and screw #13 ?? then it all just slides out together?
05-14-2015, 05:58 PM #12
Yes, pull #13 and the shift rod........ then everything but the gear will come, once the propshaft is out, the forward gear will tip out and the pinion gear will fall out
05-15-2015, 11:32 AM #135000 RPM
- Aug 2009
- Florence SC
- 249
Call me,
I'll walk you through it.
Disassembly not too bad, going back together is the PITA. really need the tool to reassemble & keep your religion.
LT
05-15-2015, 12:42 PM #14
thanks a lot Thornton, I will call you if I get to cussing to much>>> LOL
05-17-2015, 05:15 PM #155000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
tool can be replaced by using a 12ga wire 20"long.fold 3/8" of wire over and screw it into the cradle where the lower shaft threads into.put wire into prop end of gearcase and up thru shiftshaft seal,use wire to hold up cradle whyle assembling rest of propshaft then unscrew/pull wire and replace s/shaft.-th
