Results 16 to 30 of 32
    Dec 2010
    Denmark
    I am seriously considering upgrading to digital
  2. #17
    TX......somewhere?
    flaming, backfire and etc is an ign. problem.. could be as simple as idle timin'...could be worse.....
  3. #18
    Dec 2010
    Denmark
    tlwjkw,
    trust me it is timed ok, and it is only when it is Cold. When I have it started it idle fine and starts quickly.
  4. #19
    TX......somewhere?
    alrighty then.... that's all I got with "keyboard" diagnostics.. digital will be an improvement all tha way around... gl with it.
  5. #20
    Dec 2010
    Denmark
    Hey Guys
    I contacted Brucato, and purchased a digital ACU. And now I have it on my table. Looking forward to put it on.
  6. #21
    Gothenburg, Sweden
    Quote Originally Posted by A164 View Post
    Hey Guys
    Good stuff!
    Even if the ECU was not the culprit, an ACU is a nice upgrade.
  7. #22
    florence sc
    Its my understanding when converting to a digital ecu and using the analog harness, you need to hook the blue and orange wire together from the tpi plug. And to leave the tan wire tied back.
  8. #23
    Gothenburg, Sweden
    With the PCU, I think I just plugged it in.
  9. #24
    Dec 2010
    Denmark
    Hey MTOLLY,
    I looked in the wireing diagram and the wires are number 13 (TAN), 14 (ORN), 15 (BLU). and looked in the ACU connector plug and there are no pins in that location. So there are no function for these wires.
  10. #25
    Dec 2010
    Denmark
    Hey Markus,
    I think that your right, and the same goes for the ACU.
  11. #26
    Dec 2010
    Denmark
    Mounted the Brucato ACU and now it seams to start every time. Want to see if it just fires up after it has been sitting there fore a day or so. Checked TDC with dial-gauge that I purchased for JSRE some years ago.
    Re-timed I according to digital ecu settings.
    idle advance +2dg (to be within 0 to +2degree)
    Wot +25dg
    Original setting with ECU BOX 11350A15 according to service manual should be, and was set as follows
    idle advance 8dg ATDC
    Wot +25dg
    Come to think about it if the timing description for analog (a15) box is correct as mentioned above. Or that actually could be some of the hickups.
    Well I am not Building it back just for finding out. The Brucato seams to Work fine and with less smoke as well.
    Anyone have experince with A15 box and the timing mentioned above?
    On the connection rod to the trottle I have seen some engines with a slider. Mine do not have such, do i need it? And if so how to adjust it?
  12. #27
    Gothenburg, Sweden
    Wot +25dg
    Wot +25dg
    Timing should not depend on ECU, so one of them has to be wrong, unless the open throttle (see below) requires more advance, and engines with A15 ECUs came without the slider, but I am just speculating.
    The slider allows timing to advance before the butterfly opens. When in gear, you can hear the engine running a little rougher when the butterfly starts to open. I thought all 260s had a slider, but maybe the early ones didn't...
  13. #28
    Dec 2010
    Denmark
    Markus,
    I have here attached some pages from the service manual. it describes a seperate procedure for the A15 box, so that was what i followed. For me it seams to be so that primary pickup (idle timing) is pre-set and hereafter the idle is fine tuned. And then on the note: page 2C-9 says that idle pickup timing must be readjusted. So this Means while opening the butterfly to get the opertune rpms. the pickup timing point is changed and ned readjusting according to note. So may be this just make Things worse each time I readjust. I have actually tried to get a slider, however it seams to be no longer available. But I can make one my self if just I can find out how long the sliding movement is.
    Maybe the one on my engine is not original, I dont know.
ID:	318922Click image for larger version.
ID:	318923Click image for larger version.
ID:	318924Click image for larger version.
ID:	318925Click image for larger version.
  14. #29
    Dec 2010
    Denmark
    Last page in that chapter.
  15. #30
    Dec 2010
    Denmark
    Regarding the slider, do anyone know at what advance timing point the throttle butterfly should start opening?
