Results 1 to 14 of 14
Thread: Can I get some 2.4 Feedback?
04-05-2015, 08:47 PM #1
I lost a few holes today...
Using Klotz with Premium fuel, High Five prop turning 6200 rpm on the high side... she let go while cruising nice at 40 mph at 4000 rpm.
Thoughts? Suggestions?
Here is the Google Drive with the images.
https://drive.google.com/drive/u/0/#...kFYdUktS1VDdGs
04-05-2015, 09:02 PM #2
I'm no expert, but if the cylinders and pistons are somewhat oily yet I would guess overheated.
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
04-05-2015, 09:14 PM #3
04-05-2015, 09:15 PM #4
What's imprinted in the top of the piston... looks too "square" to be a ring retaining pin or a needle bearing? Almost looks like the ground strap from a spark plug?
04-05-2015, 10:18 PM #5
It has surface gap plugs... motor had plenty of water pressure and was not hot. I will pull the front half next week.
David "Tango" Wilks
Current boats: (Not All Running...LOL)
18' VT-Rocket Bass Boat: 2.5L 280 Mercury
21' Eliminator Daytona: Stripped and Possibly For Sale!
24' Skater: Uncut, Not Rigged and Possibly For Sale!
30' SeaRay 290 SunSport SLX: twin 3.0L Duramax diesels & Bravo3 drives
52' Sunseeker Predator twin Volvo-Penta IPS900 diesels
04-05-2015, 11:43 PM #6
[QUOTE=Tango;2743885]It has surface gap plugs... motor had plenty of water pressure and was not hot. I will pull the front half next week.
Sorry about your motor, that sucks!!! Please do follow this to the end and try to let us know what happened. I have a 200/2.4 and dang sure dont want the same. Good luck.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
04-05-2015, 11:47 PM #7
What do the heads look like? Snap a pic of them too? Did she seize or smoke the rings?
04-06-2015, 12:23 AM #8
QUOTE=rgsauger;2743891]What do the heads look like? Snap a pic of them too? Did she seize or smoke the rings?[/QUOTE]
Motor lost power but can be turned by hand and restarted... I elected not to push it so I immediately shut it down, got a tow back to the trailer and pulled the heads. The heads look clean save for one little ding by the tiny square object. They'll be easy to clean up. I'll take a pic of the heads tomorrow.IDavid "Tango" Wilks
04-06-2015, 07:04 AM #9
Are those pics representing 3 holes or 2.
RockTeam Junk
04-06-2015, 10:51 AM #10
Attached are the Head pics.
Thoughts? Sugesstions?
I am now inclined to believe the ring let go.David "Tango" Wilks
04-06-2015, 12:40 PM #11
Since the port side seems to be the issue I might consider the switch boxes. Looks like some early stage detonation on the piston without the square dents. JMO>
RockTeam Junk
04-06-2015, 12:51 PM #12
04-06-2015, 05:49 PM #13David "Tango" Wilks
04-06-2015, 07:40 PM #14
Man. this is like pulling teeth.
You might poke/pull it out and see if you can figure out what it is and where it came from, it might give you a pretty good idea how expensive it will be to fix.
