Results 1 to 11 of 11
03-13-2015, 05:17 PM #1Member
- Jul 2009
- ky
- 39
1994 2.5 200 mercery what is the max rpm
In put
03-14-2015, 11:24 AM #25000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
I don't have a 1994 Mercury Manual but the 1996 Merc Technician's Handbook says 5600 RPM for the 200. I would think that it would be similar for your year model. Anyone else?
03-14-2015, 06:33 PM #37000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
max rpm is relate to 2 things. the first is the oil mixing pump, which limits rpms to 6200. the second is the carriers for the crank bearing. if you have plastic carriers the 6200 again is the limit. metal carriers can go to 7 or 8000 thousand rpms.
for your motor i would limit the max to 6200.
03-14-2015, 06:46 PM #45000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
I agree with hsbob...I run a '92 200 up to 6200-6400.
03-14-2015, 10:53 PM #5
Seems like I read here somewhere that late 90's 200 EFI and 200 Promax longblocks have the same part number, but the promax has a 6750 rev limiter. Is this right?
Allison GT20
ProMax/260
03-14-2015, 11:10 PM #6
03-14-2015, 11:33 PM #7
I've got a '98 200 EFI with a 200 Promax ECU, I run premix. Am I good to run to the limiter?
Allison GT20
ProMax/260
03-15-2015, 12:37 AM #8
yeah, ya can...both same rotatin'/block assy.....
03-15-2015, 12:43 AM #9
I got a 96 225 promax premix run to 7500+ side pinned,33cc heads, 91 octain 40/1 on the same build from 10 years ago no problems runs like new.
03-15-2015, 05:51 AM #10
04-16-2018, 06:20 AM #115000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
