Results 31 to 37 of 37
11-25-2022, 11:42 AM #31
11-25-2022, 11:43 AM #32
Cap the lines to the hpdi oil pump I mean
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
11-28-2022, 11:54 AM #335000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
11-28-2022, 11:55 AM #345000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
11-28-2022, 11:56 AM #355000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
07-11-2023, 09:19 PM #36New Member
- Aug 2022
- Miami
Doing the conversion myself right now. What did you guys do with the knock sensor by the stbd side head? I see that the block has the machined spot for it but the head is in the way. Any tips would help a lot! Thanks!!
edit: did you swap the heads around ? Stbd to port and vice versa?Last edited by Juanchy; 07-11-2023 at 09:26 PM.
07-15-2023, 11:12 AM #37New Member
- Aug 2022
- Miami
Well to answer my own question, I modified the head to fit the knock sensor and I also had to cut the gasket. Now I understand why the heads where swapped around. My cowling doesn't fit because the spark plugs stick out. So if you intend to put the powerhead on a ox66 midsection and cowling switch the heads around. I fired her up and she sounds good and everything is working as it should.
Now I have to get 2 new gaskets to switch the heads around. Thanks everyone!!
