Results 1 to 8 of 8
02-28-2015, 06:00 PM #1Member
- Apr 2014
- Idaho
- 80
1995 Mercury 200 XRi - Please Check for correct Oil and Black Box Delete - PICS
1995 Ranger 392 - Mercury Black Max 200 xRI EFI
Oil Injection Deleted, Black Boxes Removed, New CDI Voltage Regs
Idle Timing - 1 AD, Max - 23 BD, TPS - .253, Stator tests good
Bosch Plugs BU8H, New Water Pump
0G129842
03-03-2015, 07:22 PM #2
If you search my name, I explained it with pictures years ago. It should have been made a sticky. I think pyro even mentioned that at the time
03-03-2015, 08:06 PM #3Member
- Apr 2014
- Idaho
- 80
I agree, it should be a sticky. Every how-to that i found had the pics removed.
0G129842
03-03-2015, 09:56 PM #4
Umderneath the starter there is a fitting with a nipple on it that you would have removed a hose from. Did you also remove the fitting and replace it with a pipe plug? If not, please do. Do not leave it open or put a vacuum cap over. Plug it with a pipe plug. If you do not, you will lean the bottom cylinder out and will cause severe damage
03-03-2015, 10:03 PM #5Member
- Apr 2014
- Idaho
- 80
I don't recall removing anything from below the starter. I will be on the road for a bit, but will check and let you know as soon as I can. What exactly is it?
I will take more pics of the engine so you can verify my sanity
Thanks again for the help.
Ah, the remote oil tank pressure hose! I will check.Last edited by mram10us; 03-03-2015 at 10:08 PM.
0G129842
03-03-2015, 10:32 PM #6
Where in idaho? My sister in law is from Lewiston
03-04-2015, 03:46 PM #7
I shouldn't have ever posted all those photos with TinyPic and ImageShack. Those bastards always delete all the good stuff a couple of years after I post it.
03-04-2015, 11:52 PM #8Member
- Apr 2014
- Idaho
- 80
MT, down by Boise.
I searched like crazy and couldn't find any good pics. Once mine is complete, I can post pics of my setup with arrows to help the next guy.1995 Ranger 392 - Mercury Black Max 200 xRI EFI
0G129842
