Results 1 to 10 of 10
01-31-2015, 03:45 PM #1Junior Member
- Jun 2013
- Covington GA
2.4 merc 200 hp. Help with jetting!
I have an old merc 200 2.4. I think 87 model but not sure? Doesn't have factory Oiler so i am not sure. Has wh-20 carbs. Velocity stacks, exhaust can out and relieved. has the 2 peice short tuner. Timing set at 24 deg. 130 lbs compression. It has .72 jets in it now. I havent run it yet but wanted to start off right. I cant find much info on the 2.4 with wh-20 carbs from the factory? thanks for any help. I am use to the 2.5s
01-31-2015, 05:08 PM #2
I think oil injection was optional in 1984 and standard in 1985. Or was it '83 and '84...?
im sure somebody has an answer to the jetting question.'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
01-31-2015, 05:58 PM #3
200 1978-1990 WH-3, 14, 18, 20, 22, 26, 28, 31, 39, 46 with 2 needles and seats 200 1994-1995 WMH-34/39 200 1996-1997 WMV-5 225 1980-1981 WH-15 / 20
I assume these are the motors and years they came from the factory with wh20 carbs. Dont know if that helps at all. If it has been modified jetting probably not factory setting anyway. JMO
01-31-2015, 09:52 PM #4
WH20'S..........1,3,4,5,6 /72's...2 /74.....46's all/idle.
there's a "build date" stamped somewhere around tha base of #2 cyl. on block half, kinda behind tha advance timin' arm...no oiler its probably gonna be first generation block..........Pyro, here's a little info for ya. it was never an option after second gen. motor came out 83/84 I think (crank driven) only electric oiler junk for older stuff was an option......Last edited by tlwjkw; 01-31-2015 at 10:21 PM.
02-01-2015, 12:03 AM #5
Yes, I was referring to the gear-driven oil injection. The first year it came out ('84?) it was an option. After that, the V6 motors all had it, right?
no factory oiler (unless it was removed) would be older than 1985.'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
02-01-2015, 12:21 AM #6
gear driven was never an option........was a standard production item on arrival .......
02-01-2015, 02:14 AM #7
Wh20's stock had .72 mains except #2 had .74. .46 idle and no vent jets. But could be on a different motor so jetting could vary.
02-01-2015, 08:17 PM #8Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,274
- 215
- 30
- 585
Wh 20's with 72/74 jets on even a stock 200 with todays gas is going to melt a piston,in my opinion.I seem to remember the first were 74 on 1,3,4,and 6,with 76 on 2 and 5. in the mid 80's a service bulletin came to dealers along with 80's and 82's to update the carbs.Most of my modded 2.4's similar to your description get 84/86,more radical motors 86/88.I would start 84/86 and do the basic checks for burn,but I don't think that will be too rich...you want a little safety margin on a lake motor.My opinion,but I've built hundreds of em,Chris
02-02-2015, 07:14 AM #9
Chris is right...80s in 1,3,4,6 and 82s in 2,5....there was a service bulliten on this a million years ago. I have also found increasing the idle air jets (to lean it) a little (like 50s) helps the idle.
Go Time
26 Regulator twin 250 EFI
02-02-2015, 08:29 AM #10
Always ran 80 and 82s in the spring and fall and and 78s in the dead of summer.
RockTeam Junk
