Results 1 to 15 of 20
    May 2011
    Sweden
    Difference: merc 280 ros vs merc 280 standard (con)
    Hi!
    I have been wondering, what's the difference between a Merc 280 ros and a Merc 280 standard (con).
    I know they have different ECU and the ros has the rev limiter set to 8 200 rpm and con 7 700 rpm, but are there any other differences? Or is the ECU the only thing that is different?
    Also, is the rev limiter the only thing that sets the ECUs apart?
    Thanks,
    Oskar
  2. Likes Forkin' Crazy liked this post
    Jul 2008
    Shreveport, LA
    Subscribed. I've also wondered If the curve was different in the 8200 rpm ROS box.
    I have the CON box and 7700 is not getting the job done. With a 24 pitch prop I'm on the limiter quick.
    http://www.screamandfly.com/showthre...interior-re-do
    1986 Skeeter Starfire 150
    2000 Ranger R81VS
    1995 Liberator
    1988 Searay Sorrento
    1986 STV Pro Comp 280 "Area 51"
    1990 STV Pro Comp
    Shreveport, La.
    I have always wondered the same thing. 280`s seem to run great until they reach the rpm limit so the stock fuel curve must be good. Can anybody remove or move the limit up without changing the curve?
    DB
    Jul 2008
    Shreveport, LA
    I've sent a message to DBR asking these type of questions.
    I like everything about how my 280 runs except the 7700 rpm limit. I'd like to turn 9K
    I will share the info when I get it. Pete
    2000 Ranger R81VS
    1995 Liberator
    1990 STV Pro Comp
    Jan 2008
    eatonton ga
    I have consumer box with no limmit several people can do it curve the same as ros con has water presure saftey feature and one other little thing i think but as far as performance goes they the same
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
    Gothenburg, Sweden
    Only difference is the rev limit and that the offshore box doesn't care about the overheat and/or water pressure (not sure which it is) alarm.
    Then, of course, there is the bass mid section and the offshore mid section.
  8. Thanks powerabout thanked for this post
    May 2011
    Sweden
    Time to update this thread.
    I have now the opportunity to switch my con box for a ros box.
    Is it just plug and play or do I need to to any other modifications? My 280 is a -05 and everything is stock...
    Cheers!
    Jun 2012
    Indiana
    It will plug and play. Didnt the ROS motors have a 1" intake spacer and a hood pin?
  11. Likes Stålproppen liked this post
    No stock 280’s didn’t have 1” spacer, ( Ros or Con ) only horned Drags cam with 1” spacer from Mercury ...
    Jay
    Jay @ JSRE
  13. Likes Stålproppen liked this post
    Loudon Tn
    Just to share my experience with 280s. Drag raced three different new 280 powerheads. Ran 260 electronics and 280 electronics (10,000 rpm limiter). No matter what pitch prop I put on them none would ever pull 9000 rpm. Blocks just aren't ported to get that rpm. Saw a couple posts that guys were doing it but my experience it didn't happen.
    be safe have fun
  15. Likes Stålproppen liked this post
  16. #11
    A stock 280’s exhaust port mapping is 1.625” from top of port to the deck , Drag is 1.530” 260 is 1.565” so the top rpms that each make top power differs ...
    Bill you are correct !!!
    Jay
    Jay @ JSRE
  17. Thanks rgsauger thanked for this post
  18. #12
    Gothenburg, Sweden
    Quote Originally Posted by Stålproppen View Post
    Cheers!
    Just switch the ECUs, but be aware of my point about the alarm from 2015 above...
  19. Likes Stålproppen liked this post
  20. #13
    May 2011
    Sweden
    Thanks for all the great input!
    I'm running a Twister 20 (2015) at 119,8 mph on the limiter at the moment.... That 120 mph mark itches
  21. #14
    May 2011
    Sweden
    Update!
    Im about to switch to a ROS ECU...Just curious: How does the toque/hp-curve look like above 7700 rpm?
    I did find a curve showing 0-7500 rpm and peek power seems to be at 7500, but what happens above? Does it drop quickly?
  22. #15
    Sep 2017
    Ashland city tn
    Nothin like testing for yourself , if u have the box , its plug and play , then see what happens after 7700, mite just hit ur mark
