Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
    alabaster , al
    Allison " drag boat" xr-2001
    ALLISON "DRAG BOAT" ----XR2001D ( for sale)....read entire post.....
    this is a true Drag Hull......not a river racer
    hull has been modified/blueprinted ......
    im not racing this year.... so its time to sale the red rocket
    1998 ALLISON DRAG:
    custom rigged by Daryl Lane ( boatworks)
    custom Boatworks fuel system with dual fuel pumps/ vapor seperator tank/aeorquip hoses
    custom Boatworks drag trim system-- delay box/12-24v--12 and 24v on the wheel -- trim computer
    digitron egt/digital rpm display
    billet shifter
    in-control shifter w/trim delay and hole-shot spring
    boatworks modified/ blueprinted hull design ( will disclose to buyer ) ---- what has been done
    this is the sister boat that DR. Walter Wolf ran in modified producton ODBA and dominated with....
    new allison steering wings/ arms-pulleys
    allison jack plate
    Factory Mercury Drag Mid---15" short ram drag ( galen burden lightened clamp bracket) ( JSRE drystacked drag tuner) w/ exhaust slots and drag cut snout..............like new............... not a cut down mid.... factory drag mid.
    JC custom drag gearcase w/ 2-hole offset allison intake ( enclosed water tube)----Hi-Perf bearing carrier and shaft---- factory mercury 15" shaft ( not a cut down one)...........Steve Tillman custom allison cut and modified skeg
    drag allison weight 490ish............
    boat is set-up and ready to race.............minus powerhead.............. for superstock/ modified production ODBA 1400lb class
    ...........should be able to make 1250lb class pretty easy............
    setup-- weight-- testing-- is ready to go ( drop your powerhead on and its 100% race ready)...........
    its showroom clean just like a new one............
    rigging is as good as it gets..........the blueprinted drag hull is as quick as you will find.......Drives like a dream
    you will not find a cleaner or better rigged allison drag / this is not a repaired or sandbar allison..... this is a custom built drag
    can be sold a few different ways.........
    full rigged allison with single axle trailer $11,990
    full rigged allison with tandem axle trailer $13,990.........
    mercury 260 cowl assy $780
    custom 15" drag mid $4800
    custom 15' drag gearcase $3450.............will not sale seperate.............boat has to sale first.............
    also...............4- yamaha drag props (3- worked by billy eaves ( perfor propeller)........(1 worked by ronnie gilbert) these drag props are worked for this drag hull............prices range from $690-990.......they are like new........
    i will make a package deal for everything listed including 3 yamaha drag props $22,800 ( includes both trailers)
    call for all the info.........205-965-8638............deliver available............. will not seperate untill boat sales........
    READ ENTIRE POST BEFORE CALLING...........calls only --- im not around to answer replies/emails/texts........call
    THIS ALLISON DRAG IS SHOWROOM CLEAN.......A SOLID 10/10.......EXTREMELY FAST.........FULLY RIGGED...RACE READY!
    BIRMINGHAM,,, ALABAMA..........if pics do not post.......call and i will email/text them to you........but call firstClick image for larger version.
ID:	313003Click image for larger version.
Name:	allison midsection rear.JPG
ID:	313004Click image for larger version.
ID:	313010Click image for larger version.
ID:	313006Click image for larger version.
  2. Likes Fear And Loathing, mercnfly liked this post
    alabaster , al
    yamaha drag propsClick image for larger version.
Name:	yamaha drag props.JPG
    alabaster , al
Name:	allison sky view.JPG
    alabaster , al
Name:	allison rear cowl view.JPG
    alabaster , al
Name:	gearcase side view.JPG
    alabaster , al
Name:	drag trailer.JPG
ID:	313015Click image for larger version.
    alabaster , al
Name:	allison top view.JPG
  9. #8
    alabaster , al
Name:	allison showrrom top view.JPG
  10. #9
    alabaster , al
  11. #10
    alabaster , al
  12. #11
    alabaster , al
  13. #12
    alabaster , al
  14. #13
    Shreveport, La.
    That is a beautiful boat!
  15. #14
    UTICA IL
    Nice boat what has in won in
    the racing I see you say its one of the fastest in the country??
  16. #15
    SOCAL, the land of 75* and sunny!
    Quote Originally Posted by jasonpijanowski View Post
    Man, you could really fly that thing with one of your famous (infamous?) Cheater motors..
