Results 1 to 7 of 7
    Mar 2014
    2007 Optimax 200HP Outboard - MI
    Standard rotation has been sold. Counter rotation motor still available.
    Counter rotating motor has 559.2 hours. No fault codes noted on the diagnostics report. There were some codes set because the motors were not mounted while testing (low oil, tilt indicator, etc) Mechanic said they were in excellent condition. Leak downs were 2%-7%.
    Motor will come with a tach, water pressure gauge, and 17 pitch Mirage prop. I would consider swapping the foot for a standard rotation for the same price but no prop.
    $5500
    Motors are mounted on shipping pallets and ready to go.<!-- google_ad_section_end -->
    Attached Thumbnails Attached Thumbnails Optimax 1.jpg   Optimax 8.jpg   Optimax10.jpg   Optimax Motor Test Results Pg 1.jpg   Optimax Motor Test Results Pg 2.jpg
    Last edited by GPappy; 01-29-2015 at 07:00 AM. Reason: Sold Standard Rotation Motor
    Mar 2014
    BTT
    Would also be interested in finding a Center Console fishing boat needing repower to put these on.
    Mar 2014
    Standard rotation motor has been sold. Still have the counter rotation motor that I will sell for $5500. The motor will include Mirage 17pitch prop, tach, and water pressure gauge.
    Jan 2015
    washington
    Is there a phone number I can call you at?
    Quote Originally Posted by GPappy View Post
    I have a pair of 200 HP Optimax motors (25") that I purchased for my Grady White but found too much rot to justify fixing it up so ended up buying an inboard boat and selling the project. They were purchased in May and were last run in April.
    Counter rotating motor has 559.2 hours and standard rotation has 569 hours. The only fault codes noted were on the standard rotation and that was for an over speed of 2606 in neutral at 373 hours and an over speed of 5750 in gear at 183 hours. There were some codes set because the motors were not mounted while testing (low oil, tilt indicator, etc) Mechanic said they were in excellent condition. Leak downs were 2%-7% on the counter and 4%-7% on the standard.
    Looking to get $10,500 for the pair and will sell individually for $5500 each.
    Jan 2015
    washington
    is there a phone number I can call you at regarding your motors?
    Mar 2014
    Quote Originally Posted by juliestephens View Post
    Will PM you my number.
    Mar 2014
    Counter rotation is still available. I picked up a 20" mid and standard rotation lower so I could put it on my old bass boat if it doesn't sell Price for motor set up as a 20" shaft standard rotation would be $6000
    Also will have the 25" mid and counter rotation lower available once I do the swap.
