Results 1 to 3 of 3
    Apr 2009
    cooya beach,australia
    What's cut reed cages and cut exhaust chest on Merc v6
    Hi all just wondering what cut reed cages and exhaust
    chest is and the advantages of this as I have a bridgeport
    Merc vp mod motor and want a bit more power
    cheers
    lindsay on. canada
    cut reed cages are where the openings in the cage is enlarged to allow more aire to pass . The exhaust chest is also cut to allow wore volume to pass .
    Aug 2009
    Southeast Texas
    Unless you are racing I wouldn't worry about cutting the reed cages. I would start at the beginning and go from there. Have you maximized your setup already? (engine height, prop selection, hull weight distribution, etc) How much compression do you have now? Having the heads cut to raise compression is probably the single most effective thing you can do to increase power. What carbs are you running? Carbs can make a difference. A 1" Spacer like those sold by Chris Carson can improve mid range on a carb motor too. All that without cutting on the block.
