Results 1 to 15 of 38
Thread: Changing ECU
03-13-2003, 08:12 AM #1
Changing ECU
I'm changing from an Anologe to a Digital A-6 on my 2.5 260! Woo Hoo! I'm changing to 56 lb PR, and a new Bosh Fuel pump.
But my question is: Do I need to change my timeing?
Do I just disconect my TPI and remove?
Is there anyhing that I should think about?
Thanks!2009 Summer Thunder 8 second winner
2009 Smokin in the Cove 8 second winner!
2010 Summer Thunder 8:00 #1 Qualifier
2010 Smokin in the Cove 8 Second (2nd Chance) Winner!
www.pacificpowerequip.com
http://www.jaysmithracing.com/
http://www.lucasoildragboats.com
03-13-2003, 08:33 AM #2
According to the instructions that Tony Brucato furnishes with his ECU, "the battery should be disconected before changing any ECU".
03-13-2003, 10:52 AM #3
Map Tube Elbow
The elbow on the horn has a different size hole. Some say it doesn't matter but it ain't worth it not to change the $2 part.
David
03-13-2003, 04:31 PM #4Supporting Vendor
- 11,838
- 163
- 11
- 795
Elbows
Mike ,
I keep them in stock !Jay @ JSRE
03-14-2003, 08:19 PM #5
Changes
You need to change the nipple in the air horn to the smaller one, If your analog had an external TPI you need to cut the 3 wire harness back and solder the blue and orange together. The idle timing on the Digitals is higher than the analogs but you may have to do that by ear because you don't have the correct air haorn and bracket with the throttle plate cracker on it
03-22-2003, 01:16 PM #6
Bill Gohr, Why do I have to solder Blue and orange wires together? What do they do?
Thanks for the Advice!2009 Summer Thunder 8 second winner
03-22-2003, 09:56 PM #75000 RPM
- Apr 2002
- Wenatchee, WA
- 778
Ana. to Dig. ECU
Would all these things apply to going digital with a 2.4 BP as well?
Thanks, Dean
03-22-2003, 11:17 PM #8
Yes, If you dont cut and solder Blue and orange, the ECU will have no clue what Throttle % you are at and will run like as_.
Skydog Am i right Bill?2011 DCB F26
2017 300 XS DBR
03-23-2003, 01:14 AM #95000 RPM
- Apr 2002
- Wenatchee, WA
- 778
Thank you Skydog!
You just saved me alot of grief. I neglected to mention I had an A-7 converted to an A-40 by Rapair and had them add a dash enrichment pot. I don't think the dash control would make a difference, but my first thought would have been a faulty ECU when it ran like crap. I was even told that I didn't have to do anything except yard the ext. TPI, thought that sounded to simple.
Thanks Again, Dean
03-23-2003, 07:56 AM #10
OK, So you mean? Solder the blue and orange wires at the harnes right? Now can I just use one of those clamps that join two wires together? Like you buy at Pep boys for 12 volt wireing? will that work temp? Permanant?
I'll tellyou this, I ran it without the wires soldered together, and it acted FAT! We leaned a little and it still was not crisp! I'm going to join wires today and let you guys no tonight if I see any differance!
This board ROCKS!
Thanks for the help!2009 Summer Thunder 8 second winner
03-23-2003, 10:26 AM #11
MY 2.5
changed from an Anologe to a Digital, it ran very poor took it over to Bill , he pointed it out to me. He cut the plug off and did the change boat runs alot better!Thankyou Bill
Good luck guys!
Skydog P.S. Cut the plug off and Solder and heat wrap it!2011 DCB F26
2017 300 XS DBR
03-23-2003, 10:28 PM #12
Those wires
complete the circuit for the map sensor. Doesn't matter whether its a 2.4 or not. When Skydog brought his stuff over there it ran like S__t. After a little touch up it came alive. You can use the jumper in the plug but I've seen more than one of those that fit loose and gives you inconsistent running. Just cut'em and connect them right be done with it. Make sure you change the nipple in the airhorn otherwise it will run rich at idle and that will make it not sound crisp also. If you had a 2.4 did you move the wire for the choke (enrichener) off the starter solenoid also that will make it load up at idle also every time you start it. I still find ones that haven't been updated yet so ya gotta look.
Also, don't forget to change the spark plugs, suppression plugs work the best I use the Champ QL77JC4's at .030Last edited by Bill Gohr; 03-23-2003 at 10:30 PM.
03-23-2003, 11:14 PM #13
Bill, I conected the blue and orange wire's today. I still have not changed the nipple.
It ran very fat! Had very oily plugs, and cavitation plate was covered in smoke. EGT never got above 900.
I beleive my A-6 ECU is set on 100, it was about 65 degrees today, with about 60% humity. I'm running NGK-BUZHW plugs. I just changed to 26cc heads, but I thought they would make it run leaner. No?
Do you think the nipple would make it run fat on the top end too? I will replace it ASAP, and see how she does.2009 Summer Thunder 8 second winner
03-23-2003, 11:26 PM #14
Fat on top no
What Fuel presure reg do you have on it? Dark green or gold?(should be dark green) Look at your return line. Make sure it is free of debrie.Make sure your vac. line going to you ecu is not pulged.Or the little elbow coming out of the peltum is not pluged. Ohm out your air temp sensor. Make sure your battery is Fully charged.
SkydogLast edited by skydog; 03-23-2003 at 11:29 PM.
2011 DCB F26
2017 300 XS DBR
03-23-2003, 11:33 PM #15
Skydog, I have the black (Or Dark green I guess) 56 lb. How, what and where do I OHM out? air temp senser? Where is that? Battery is fully charged always.I'll go through the nipple and lines when I change them Monday.
Thanks you guys!2009 Summer Thunder 8 second winner
