Results 1 to 6 of 6
    JUPITER, FLORIDA
    Mercury Pro XB-250 cylinder heads...
    What is the difference between the XB250 heads vs the stock 3.0L 225/250 heads?
    J-Town Hot Boat Team
    Barracuda 188CCR/Suzuki 140
    Past Boats:
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT Bowrider/Merc 175
    Talon T-21/Mercury Racing 2.5 Carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/Mercury 454 Magnum
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat/Mercury SportJet
    SeaRay 17' Seville/Merc I/O
    Naples, Florida
    It depends on the years but a few cc's less
    Yantis, TX
    Biggest difference is the block and porting.
    "We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing."
    JUPITER, FLORIDA
    Can the stock 225/250 heads be interchanged with the Pro XB 250??
    Past Boats:
    You will loose about 10psi if I remember correctly
    Naples, Florida
    Early style 225/250/300pm is real close in Port timing. If you put 250xB heads on a stock 225/250 you will gain a little compression. The main difference between the 250 xb and all the rest of the older efi blocks is they removed the compression relief slot (cat eye).
    What you should really be looking for is a set of c10 300pm heads. They would end up putting you in the 130 lb range.
