Results 1 to 6 of 6
    fort lauderedale
    1992 175 intruder bobs cone and torque tamer ran 89.6 on my allison stock compression
    Have had this motor for 10 years ran great on allison river racer at 89,5 bumping the rev limiter rode with several people that can confirm, now on 1969 magnum marauder 16 and after 65 the boat chine walks to heck pulling 26 allison cut chopper that comes with motor need to slow down the magnum before I get into trouble trying to get past the chine walk
    stock compression rev limiter still in, have spare gray lead power pack ez to defeat the rev limiter ficht reeds gave a few hundred rpm bobs cone custom inlets only 3 feed the motor 20 plus lbs of water pressure gutted cowling is lightweight and 32 3/16 holes in front runners give ram air right to the upjetted carbs
    so you want a ready to go bolt on motor for your allison,hydrostream action or light bass boat like a bullett these 175's are light strong and fast and this is bolt on and go some nicks and scratches, needs no work fresh water pump...you supply your steering the k-10 is going on the smaller motor
    3850 $
    Nov 2014
    Moss point ms
    will you take $3000?
    Nov 2014
    Moss point ms
    $3000?
    fort lauderedale
    yes I will and you can bolt onand go how would we make the deal????
    Central NJ & Ft. Pierce, FL
    Please read the pm I sent you. I need your contact info
    Is this motor still available?
