Results 1 to 15 of 26
Thread: 2.5xs
    Jul 2013
    2.5xs
    Has anybody torn down a 2.5XS? Been comparing parts for the 2.5XS and the 200XS. Different part numbers for block, crank, throttle body, air handler, reed plate, etc.
    Know the crank is different for the 3.0 splines. Can anybody shed some light on the other parts differences?
    Curious about the reed plate as the parts picture shows some kind of extensions on the front of the reed plate. Looks like similar thinking as the S3000 F-1 SVS style intake with the different length extensions on the front.
    Is the throttle body different with a larger butterfly? Is the air handler different to facilitate the reed plate with the extensions?
    Jul 2013
    Somebody out there must have been inside a 2.5XS. Anybody with some info?
    Jul 2009
    West Coast, FL
    Curious to know also, as I have one and it a very impressive motor.
    Naples, Florida
    2.5xs reed plate
    Jul 2013
    Very interesting! Looks like they are trying to tune the intake pulses but yet has open sides. Is the air handler deeper to handle the extra length of the reed plate?
    Does it have a larger bore throttle body?
    Naples, Florida
    Air handler is the same and the plate runners fit tight on the sides. I have taken a 135/150/175/200 sport jet and 200xs apart trying to find the differences and best parts. The 2.5xs is very similar to the newer 200xs race including grey injectors and higher air fuel pressures. The newer race only 200xs motors have the higher port timing almost like a 280. The older 200xs were more like a 225 promax. I have taken an older 200xs and had it ported like a newer one. Can't wait to see the difference. Going to use the 2.5xs reed plate also (should help get the low end torque back to compensate for the higher porting).
    Jul 2013
    Interesting that the air handler is tight on the sides of the reed plate extension. No loss in airflow by reducing the intake path area for each cylinder.
    Sounds like an interesting build you're doing. What ECM are you planning on using?
    Please keep us posted and thanks for the info on the different 2.5 Opti's.
    Naples, Florida
    Having Simon work with me on a custom tune.
    Jul 2013
    So when you say the genII 200XS is similar porting to the 280 can you be more specific? Is it the same port timing? Same exhaust chest cut?
    Naples, Florida
    Cylinder sleeves are just a little lower than 280. Exhaust chest is like a promax not a 280.
    Jul 2013
    All ports compared to the 280?
  12. #12
    Naples, Florida
    Advanced sleeve offers a replacement for the new ros 200xs/200xs sst
    Part number: 1241
  13. #13
    Naples, Florida
    200xs sst
  14. #14
    Jul 2013
    Is that a GenI or a GenII 200XS SST?
  15. #15
    Jul 2013
    Quote Originally Posted by Todd D View Post
    Part number: 1241
    I was looking for them with LA Sleeve and they didn't have it yet. Will look into Advanced Sleeve.
