Results 1 to 3 of 3
10-21-2014, 05:29 PM #1Junior Member
- Aug 2013
- Rochester, NY
- 11
2000 johnson 200 powerhead. NY. $1700/bo
2000 jl200plssc. 3.0l looper. This is a dressed and complete powerhead including main harness. This motor came on an action 18 I bought in the summer of 2013. Previous owner claims it was rebuilt in early 2013 after a ring snagged. Has Milled heads 125psi?, cylinders cleaned up by Monty. *not a true "stage" port job* mid bore carbs. I ran this motor for around 5 true hours last year before having gearcase issues. Motor ran strong and would push my action 18 to 85mph+. Fogged and pulled powerhead. Has been stored since. Bought a 2.5 260 and no longer need this motor. Also have other omc parts including a hood and pans for this motor,disassembled gearcase, dry stacked mid/exhaust adapter. Located just outside rochester, NY. Phone # is 585-738-6794
$1700/BO for powerhead, 2k takes all the omc stuff I have.Last edited by Upstaterpaul; 10-21-2014 at 07:43 PM.
10-22-2014, 06:25 AM #2Member
- Oct 2002
- New Hampshire /new york
- 36
what OMC stuff do you have ? do you have a mid for this motor?
10-22-2014, 09:05 AM #3Junior Member
- Aug 2013
- Rochester, NY
- 11
Mid is a 20" dry stacked. Has a crack at one of the mounting bolt locations. Lower is in rough shape. Bad case, driveshaft and carrier. Gears look to be fine. Have dual opposed teleflex, main harness, basically all parts to complete this. Things would need to be one through/rebuilt other than powerhead.
