Results 1 to 5 of 5
    multi engine set-up engine centers
    I have always set-up 3 and 4 engine boats with the motors being @ 18" centers ...a buddy of mine just bought a 3 engine boat with the motors @ 25" centers ....with the center engine mounted high with a water pick-up on the transom...I am going to go through the motors before we run it...but I just wondered if anyone thinks that it could be as fast being set-up that way...Motors are Merc's....
    Jul 2004
    houston,tx
    what hull is it? what motors?
    if alien cowled the centers have to be further out
    as the old 260style cowls were narrower and commonly woulg go at 18" centers
    I have an offshore v bottom boat
    that I have trips on it with 260 style cowls at 16 1/2 centers
    to get props as close as possible for the 26deg v of this skinny 6'.6" hull
    Jul 2005
    Baton Rouge, LA
    The alien cowling is 22" wide so they won't fit on 18" centers.
    the motors are pre bridgeport 2.4 mercs,the boat is a 30' corsa..deep -v...& don't the cowls hit when there are 16 1/2 centers....
    Jul 2004
    houston,tx
    the martini and my hull are similar
    I have a 27" Kevlar excaliber with triple offshore 260+ motors
    closer together they are on these hulls
    helps the ride and also keep water in the 2 outer motors
    as when over 70 when hull lifts props get high
    no cowls don't hit,,,,,will do full turn with the side steer
    I have no bungies on sides of cowls,,,,,,just bungies on front & rear of cowls
    with offshore upper cowl brackets
    this gives 1" closer
    then when I made my bottom pans
    I offset the mounting plate 1/2" from center on the L & R motor
    that gives another 1/2"
    1 1/2" total closer pr motor 3" toal closer together for all 3
    and this hull is set up for 100+ and wave jumpin
