Results 1 to 1 of 1
10-02-2014, 09:07 PM #1Junior Member
- Aug 2012
- Bullhead City, Az
- 25
I made a video showing the tear down of a Johnson Evinrude 1975 nitro gear case
Some of you might not be working on your own gear cases so I thought I would put up this video showing whats involved with tear down as well as the tools needed to do it. The gear case I used in the video is what I thought was a 1975 Johnson Stinger 75 hp straight skeg gear case, but it ended up being a 1986 Johnson 15" 50 Hp. The are almost exactly the same but the gears are different as you know on the 75 hp.
I will also be doing a video showing how to setup the clearances in the gear case and re-assemble it.
Reg
http://youtu.be/la5VCSBb3Go
