Results 1 to 15 of 26
    Feb 2005
    cayman islands
    When is shimming a lower unit required?
    When is shimming a lower unit required? I disassemble two lower unit to take the internal out of one to put in the next is shimming required ?
    Mar 2011
    Virginia
    If you replace the gear set, drive shaft, bearings (forward gear or drive shaft) or gear case. I may have missed one, but one of the gear case experts will be along soon.
    Go Time
    26 Regulator twin 250 EFI
    shreveport,la
    If any of the components are changed it needs to be set up with the tools correctly. This includes swapping internals to a different case
    Erik Kiser
    Jul 2013
    Quote Originally Posted by Dennyhydrostream View Post
    Definitely need to check when changing case.
    Mar 2011
    Virginia
    On a standard rotation unit, you can change the prop shaft, reverse (only) gear, shift shaft or bearing carrier without shimming. None of these affect the positioning relationship of the pinoin and forward gear.
    Go Time
  6. Likes InjectorService, stoker2001 liked this post
    Jul 2002
    FT WORTH, TEXAS
    GO X2 but the rest has to be set up all over again or BOOM soon real soon
    Feb 2005
    cayman islands
    Thanks for the info guys
  9. #8
    What about if you dissemble everything just to shorten the driveshaft and readsemble?
  10. #9
    Dec 2001
    Just a Shorten of shaft.... np........I know a guy that says that the shims are just too make up for the case machineing varianes.....the shafts and bearings are held close from Merc........so the shims stay with the case........just one opione.....JMO.....ck pinion hight......sorry for bad spelling..... late wisky 12.00.......
  11. Likes Aaronhl liked this post
    Dec 2001
    OK......just set the pione hight.... feall the front... slack.....yes.....the slack.....then ya go.......
    Nov 2019
    Canada
    It's probably worth at least checking after reassembly.
    www.InjectorService.com
    Call/Text - 204-326-0390
  14. #12
    Quote Originally Posted by roadkill636 View Post
    InjectorService
    I was kinda thinkin the other way around .. See if this makes sense.
    If it's sloppy before you take it apart, it's going to be just as bad when you hang it back together ... Pretty simple to check back-lash and then pinion ht. as it's coming apart.
    Lets you know where you stand and what adjustments that need to be made before / during the time it's being put back together ..
  15. #13
    Nov 2019
    Canada
    Thanks Chaz, I think that's where my head was going but my fingers never made it there.
  16. #14
    I just did one the other day ... so it's fresh in my mind ...LOL
    If I do another one 6 months from now ... remind me how I do em ..
  17. Likes InjectorService liked this post
  18. #15
    Dec 2001
    That's good advice Chazz......
