Results 1 to 2 of 2
Thread: Stv pro comp sprint
09-28-2014, 08:54 AM #15000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
Stv pro comp sprint
hello all i just finnished putting together an stv procomp with a sprint bottom, iv had it on the water 3 times so far managed to hang on up too 93mph,
my set up ..
sea star steering
center steer ,
1 seat,
5 gal fuel cell,
8" setback
motor: 84 2.4l mod vp 170 psi,cross drilled intake, glass reeds, wh39 carbs , light flywheel , 2.5l tuner. 150 hp cowl
gear case: merc 200 with bobs cone.
prop: 28p merc ET worked by dah.
i started with the prop shaft even with the pad i ran 91 moved up half an inch and ran 93 with 20psi water pressure
here is where i have some questions... what is the hullspeed on the sprint bottom, what could/should i change on my setup, i want too push this hull too its limit, i dont want too run over its limitations.. so far its been good
https://www.youtube.com/watch?v=yw39...ature=youtu.be slow ride about 75-80 mph
09-28-2014, 09:22 AM #2
I know for a fact that the sprint Hull can handle 123mph maybe more ours ran that back in the 80s with a 3.4 merc
